Author Topic: Re: Flat Battery  (Read 1328 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Flat Battery
« on: 08 December 2009, 15:49:43 »
Turn the key fully to open (will be stiff) hold the door handle open as you are turning the key, door should open.  :y
  • Online Online
Re: Flat Battery
« Reply #1 on: 08 December 2009, 16:32:14 »
Hi All,please can you advise me on how to get open a 2.5 CD that has a flat battery. i.e Central locking wont,also tried key in door,but to no avail,but i can get boot open but cant get into cab.Any ideas would be greatly appreciated.
You can use a long slim screwdriver to drop one of the seat backs, it can be done - i did it many years ago on my Senator when I deadlocked myself out of my delocked car by leaving the lights on.
Or you can remove the boot light and put its wires to a 12 volt supply and unlock via the remote in the normal way!  :y (Done that too when I couldn't get in using Zirk's method  :y)
Stevie-blunder
  • Wolverhampton
Re: Flat Battery
« Reply #2 on: 08 December 2009, 17:16:39 »
This does work, You'll think key will break but it doesn't  :y
davethediver
  • Blackburn, Lancs.
Re: Flat Battery
« Reply #3 on: 08 December 2009, 17:27:19 »
Used this method on a ford focus to gain entry before now. :y
The other halfs car when she locked the keys in. Thought i better add that  ;D ;D ;D
« Last Edit: 08 December 2009, 17:28:07 by davethediver »
P.A. Caron de Beaumarchais
