Author Topic: small hose from cam cover to breathers  (Read 1851 times)
mathewst
  • Split, Croatia
    • v40
« on: 08 December 2009, 14:51:22 »
Can anybody tell me the diameter of the small hose (in mm preferably) which goes from cam cover to the back side of the breathers My original hose fell apart was in very bad shape and couldn't read the numbers on it. I didi put a replacement (6 mm if I recall correctly) but am afraid it is too small and can cause problems. Thanks
Re: small hose from cam cover to breathers
« Reply #1 on: 08 December 2009, 19:20:25 »
where's that Tunnie fellow when you need him?
One for the 2.2 owners.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #2 on: 09 December 2009, 07:15:34 »
I'll try and measure it today, if I have time.
I like red cars
mathewst
  • Split, Croatia
    • v40
« Reply #3 on: 09 December 2009, 08:41:30 »
Ok thank you.
Just one small notice.
I thinh both 6mm and 8mm hoses are of the same thickness outside.
Inside diameter is what matters I believe.
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #4 on: 09 December 2009, 09:28:10 »
Easiest way is to measure the metal pipe the hose goes onto, you will find that it has a raised section at the end that the flexy pipe is pushed over and the straight section immediately behind the raised bit is the internal diameter of the flexy pipe you need.
gudluk
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 09 December 2009, 09:32:05 »
Hmm good idea.
I'll probably do that his weekend if no one writes the info first.
« Reply #6 on: 09 December 2009, 10:45:55 »
at work at the mo (i know! wtf!  ;D)
Can't recall how thick it is, if you like i can get you one from the Vx dealer here, and post it to you? I remember buying one as its cheaper to replace than buy a can of carb cleaner.
Think it was £1.20 or something silly.....
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 09 December 2009, 11:42:32 »
Thanks for the offer Tunnie but I can buy it here easily just have to know the diameter.
mathewst
  • Split, Croatia
    • v40
« Reply #8 on: 09 December 2009, 13:20:47 »
One more thing Tunnie.
Did you ever change the petrol filter on yours(if it is saloon)?
I saw a how to in the maintenance section but it is for estate. I actually have no idea where the filter is for saloon, and still cannot check anything since my mig is still in friends hand :'(
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #9 on: 09 December 2009, 17:07:08 »
It's up behind the right hand rear wheel. Half an hours job to change.
I like red cars
« Reply #10 on: 09 December 2009, 17:24:53 »
As above, also worth wearing some googles for it, as if its old they have a nasty habbit of covering you in petrol.
Also make sure it goes on the right way (it has a directional arrow)
The bl00dy monkeys who woked on my car before i had it, mounted it the wrong way!  >:(
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #11 on: 09 December 2009, 18:18:33 »
...and don't forget to buy the clips that go with it.
I like red cars
