Author Topic: front wing removal  (Read 1366 times)
GBS100
  • MIDDLESBROUGH
    • 2.2 cdx auto
front wing removal
« on: 09 December 2009, 14:02:23 »
hi i need to change the front wing on my 1996 gls saloon .does anyone know how bad a job this is.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: front wing removal
« Reply #1 on: 09 December 2009, 14:14:13 »
just bumper off light out undo bolts, take wheel off undo the plastic wheel arch, undo the bolts, may need to pop the spot weld near the A frame if it was welded, then have to put flat screw driver in the gaps to pull off the wing as tere is sealent inbetween the wing and fame. :y
ScaniaV8
  • Luton, Bedfordshire
« Reply #2 on: 09 December 2009, 14:54:54 »
Another job I need to do soon to replace my drivers side front wing....so now i know how !   Thanks  ;D
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 09 December 2009, 14:58:18 »
i didnt with the four ive removed. :-?
holtender
  • Suffolk
    • 2.5 CDX Facelift
« Reply #4 on: 09 December 2009, 18:31:47 »
I took one off six months ago and I'm sure my bumper stayed on.
Is there a weld?
« Reply #5 on: 09 December 2009, 18:34:01 »
There's a bolt/self tapper at the bottom of the A post that's visable when you open the door.
rustym95
« Reply #6 on: 09 December 2009, 19:21:15 »
mine has strutes from wing to the bumper, held on by 2 10m bolts, and there is 2 spot welds on A frame 3inc apart holding the wing on on both sides.
    • 530D M Sport, 330i Coupe
« Reply #7 on: 09 December 2009, 19:43:32 »
Early (94/95) wings are slightly different.
