Author Topic: td screeching turbo  (Read 1303 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
td screeching turbo
« on: 09 December 2009, 09:53:13 »
posted awhile ago re whistling sound. turbo was suggested well guys its screeching at me.whats the cause & is there a cure? i,m lost . ta :)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: td screeching turbo
« Reply #1 on: 09 December 2009, 09:57:27 »
not sure too be honest mate but it don't sound good  :(
i'm breaking a td at the moment if you need any bits  :y
engine was v good  :y
damage consultant
  • falkirk (sunny scotland)
« Reply #2 on: 09 December 2009, 20:56:28 »
Turbos should only make a low pitch soft brief whistle when put under load.
loud turbos are broke check air intake at manifoid (after turbo)for excess oil.
personaly i'd change it :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 09 December 2009, 21:17:12 »
Remove the elbow hose, and grip the spindle nut between your fingers.
If you can feel noticeable movement, then the spindle bearings are shot. Also, try spinning the blades, there should be no roughness when rotated. Another dead giveaway are visible metallic deposits when the elbow's removed. Any or all of these symptoms mean a replacement turbo.
« Last Edit: 09 December 2009, 21:20:47 by Reliance505 »
charlie
  • sunderland
« Reply #4 on: 09 December 2009, 21:44:47 »
there was a post a while ago(think it was turk) who snapped his intake manifold on refitting of it. iirc that made a high pitch screeching sound.
Seth
« Reply #5 on: 09 December 2009, 21:59:53 »
Aye, I seem to recall this too.
Could the screeching noise be being mistaken for a high-pitched whistling sound. Or, could even be a split on the induction side, or an obstructed air filter.
raywilb
    • Citroen C4 Cactus
« Reply #6 on: 09 December 2009, 22:28:29 »
hopefully no rain tomorrow & i shall follow your advice.  :y :y thankyou
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 10 December 2009, 08:44:54 »
pm sent  :y
