Author Topic: X30XE vacuum pipe map/plan?  (Read 2648 times)
Blackie_No1
  • Ballyclare N.Ireland
    • Omega Elite 2.5
« on: 06 December 2009, 15:39:33 »
Does anyone have a plan or a map of where all the vacuum pipes should go?
2000 Omega Elite 2.5 V6
Blackie_No1
    • Omega Elite 2.5
Re: X30XE vacuum pipe map/plan?
« Reply #2 on: 06 December 2009, 20:13:06 »
It does indeed, cheers mate, tomorrow night is booked for my garage now lol
Blackie_No1
    • Omega Elite 2.5
« Reply #3 on: 07 December 2009, 09:01:01 »
Wait a mo, doesn't show connection to the fpr?
  • Auckland
    • Mazda MPV
« Reply #4 on: 07 December 2009, 09:26:32 »
fpr?
Blackie_No1
    • Omega Elite 2.5
« Reply #5 on: 07 December 2009, 10:55:00 »
Sorry, old habits, Fuel Pressure Regulator. There should be a vacuum hose connected to it as well
  • Auckland
    • Mazda MPV
« Reply #6 on: 07 December 2009, 12:36:55 »
The fuel injectors want a constant differential pressure between the fuel line and the inlet tracts so I think the regulator has a direct line to the inlet manifold.
I had my inlet manifold off a few weeks ago to change the thermostate but I cannot remember where the fpr vacuum pipe connects to  :-/
  • Auckland
    • Mazda MPV
« Reply #7 on: 07 December 2009, 12:49:17 »
I think it is probably the 8mm flexible rubber hose that clips onto the cable tray on the passenger side (the one that stops you getting to the spark plugs).
« Reply #8 on: 07 December 2009, 13:06:40 »
Yes, its the rubber hose that comes from the main feed pipe to the idle control valve....unlike some cars, its not at true manifold vac.
Blackie_No1
    • Omega Elite 2.5
« Reply #9 on: 07 December 2009, 14:03:38 »
Thanks folks, will be out with a torch and a heater tonight lol
Blackie_No1
    • Omega Elite 2.5
« Reply #10 on: 09 December 2009, 20:33:46 »
Sorted! . . . . I think lol. The only ones I ain't sure about is what way round they go on the multi ram vac sensor
Blackie_No1
    • Omega Elite 2.5
« Reply #11 on: 10 December 2009, 14:37:57 »
Does anyone know the proper name for the vac operate valve that has an electronic plug at one end and then a vac feed pipe to it from the back of the engine and the a vac pipe to the diaphragm valve that actually moves the Multiram flap.  This isn't working not matter what way round I have the hoses to it so I am assuming that the valave is not working
Pete Elite
  • Uxbridge, Middlesex
« Reply #12 on: 10 December 2009, 16:47:28 »
      Do you mean this one:
                http://cgi.ebay.co.uk/VAUXHALL-OPEL-OMEGA-VECTRA-SWITCHOVER-SOLENOID-VALVE_W0QQitemZ170264511099QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item27a48e427b
