Pages: [1] 2 3  All   Go Down
Author Topic: Rear Bushes??  (Read 4439 times)
richard1967
  • Swindon
Rear Bushes??
« on: 02 December 2009, 20:10:48 »
Hi everyone,  Im a newbie.  Wonder of you can me.  Ive got an 02 Omega Estate 2.2.  Apart from the fuel economy its a fantastic car :-)  Ive been having a problem recently that I can only describe as though Im driving on Ice.  At any speed the back of the car will sometimes slide out slightly.  Theres no knocking noise or bumps etc.  The problem happens on any road.  I was driving in the first lane of the M4 yesterday and it was a nightmare because the rear end  was popping our every now and again.  Any help or suggestions would be grateuflly received.  Thanks!!!
mm290567
  • lanark
    • 2.5 v6 auto ELITE
Re: Rear Bushes??
« Reply #1 on: 02 December 2009, 21:02:55 »
had same problem with my saloon turned out to be wheel camber....hope this helps
richard1967
  • Swindon
Re: Rear Bushes??
« Reply #2 on: 02 December 2009, 21:31:27 »
Did a visit to your local tyre place resolve it??
Re: Rear Bushes??
« Reply #3 on: 02 December 2009, 21:37:27 »
No idea where you are .. (might be worth sticking your location in your profile) ... :)
But the general consensus is that for ANY suspension/tracking/steering problems  WIM  (Wheels In Motion)  http://www.wheels-inmotion.co.uk
Chesham, Bucks
are the best, and you get a discount if you tell them you are an OOF member.
I cannot fault them in any way
richard1967
  • Swindon
Re: Rear Bushes??
« Reply #4 on: 02 December 2009, 21:44:22 »
Hi Im in Swindon.  Perhaps I could do the trip on the weekend.  I need a new tyre on the back anyway because of a puncture.  Can you guys recomend anyone nearer to Swindon at all?? Thanks!
Re: Rear Bushes??
« Reply #5 on: 02 December 2009, 21:52:29 »
I'm Swindon (well just outside) but went to WIM to have mine sorted .. hour and a half to get there and well worth it .. even though I had to go twice !!!  First time Tony just told me the wishbones were shot .. no charge for the inspection.... changed them and went back .. car was transformed...   :y :y :y
Cotty
  • Darwen,Lancashire
Re: Rear Bushes??
« Reply #6 on: 02 December 2009, 21:54:05 »
Hi and welcome to OOF :y
I had this very same problem on my 98 V6 Saloon.I'd only had the car a couple of days when the handling issues started ie. back end going at low speeds at roundabouts and bends also hit some water on motorway(nearly s**t myself) my local garage found no fault,said it was my driving!! No way so I took it for an early MOT where he promptly found that the drivers side rear coil spring was snapped at the bottom!!
Had that fixed and now the handling is spot on in all driving conditions :y
Before I knew what it was I was thinking of getting rid it scared me that much!! 18 years of driving with no at fault prangs so I knew it was'nt me.
A quick way to check is to run your finger around the coil all the way to check as they are hard to see where they're seated.
I'm not saying yours is the same problem,just worth a check :y
richard1967
  • Swindon
Re: Rear Bushes??
« Reply #7 on: 02 December 2009, 22:00:41 »
Thanks for that.  Ive just had a look at their website, and theyre open on a Saturday, so I may do the visit then.  As a matter of interest.  Am I looking at a small fortune to have the wishbones replaced?? Cheers
Re: Rear Bushes??
« Reply #8 on: 02 December 2009, 22:06:49 »
Wishbones you can do yourself ... I'm no spanner wielder but did both mine in a day .. there's a very good guide here. Parts were about £130 IIRC.
Would have been done in 1/2 the time if 1) I hadn't had just one bolt that would not undo .... brute force eventually won 2) I'd known what I was doing!!! The second one took half the time of the first one !!!
Always worth ringing WIM first and getting a time slot .. they do get very busy and being "booked in" is preferred
« Last Edit: 02 December 2009, 22:07:53 by entwood »
mathewst
  • Split, Croatia
    • v40
Re: Rear Bushes??
« Reply #9 on: 02 December 2009, 22:09:07 »
I'm pretty good at english but can someone please define "camber" a little.
I have no idea what it means and can't find a decent translation anywhere
Re: Rear Bushes??
« Reply #10 on: 02 December 2009, 22:12:28 »
richard1967
  • Swindon
Re: Rear Bushes??
« Reply #11 on: 02 December 2009, 22:14:14 »
Hi Cotty.  Ive jusy gone out with a torch and scrambled around.  I felt both the springs on the back.  And the one on the off side, the paint on the spring has flaked off, on he last bend.  This couldnt be it surely??
Interestingly enough when I look at the back of the car the bottom of the rear tyres seem to be stuck out alot further than the tops.  So could this be a camber problem?????
« Last Edit: 02 December 2009, 22:20:09 by richard1967 »
mathewst
  • Split, Croatia
    • v40
Re: Rear Bushes??
« Reply #12 on: 02 December 2009, 22:22:03 »
Entwood so ifI get it correctly camber is set up on machine when car is raised from the ground and they atach those arms to the wheels.
Am I right?
Re: Rear Bushes??
« Reply #13 on: 02 December 2009, 22:29:00 »
Camber is one of the settings checked on a full geometry check, it is done with the weight on the wheels.
WIM uses a laser system to check the full geometry.. many places cannot check camber as they don't have the equipment, but if you read the camber basics write up on WIM ... camber can kill a set of tyres in 1000 miles .. :(
You'll need to find somewhere in Croatia that does "Full geometry" and not just "tracking/wheel alignment" ..
« Last Edit: 02 December 2009, 22:30:30 by entwood »
Cotty
  • Darwen,Lancashire
Re: Rear Bushes??
« Reply #14 on: 02 December 2009, 22:31:24 »
At each end of the coil the spring curls round to a smaller end,you'de be best jacking the car up to take the pressure off the spring and tracing from top to bottom with your finger to make sure there are no fractures,breaks etc.
A bit of paint flaking off is'nt a problem unless there is damage there,you mentioned a gouge ?? is there an actual crack in the spring?? if so it'll need replacing.
If in doubt take it to your local garage where you should get a free inspection/quote.
I paid £80 for coil spring and handbrake sorting thats parts and labour. Hope of help :y
Pages: [1] 2 3  All   Go Up
