Author Topic: Loud ticking sound, worse when hot  (Read 1427 times)
NiallyV6CDX
  • County Down
« on: 11 December 2009, 22:01:31 »
Hi folks,
There is an increasingly loud metallic ticking sound coming from the mid/bottom of the engine. Its not that noticeable on startup but gets progressively louder as the engine warms up. Its not the tappets as I cleaned and replaced them, and I did a compression test and it doesn't seem to be the piston rings either (also the ticking is too low frequency for that). Any ideas? :-?
Re: Loud ticking sound, worse when hot
« Reply #1 on: 11 December 2009, 22:05:13 »
pop off the aux belt and start the engine (do NOT run it for more than a few seconds) because the aux belt drives the waterpump.
With the aux belt off, see if it makes the same noise
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 11 December 2009, 22:23:52 »
And replace it immediately if it is the waterpump, cause mine broke in one day like that
NiallyV6CDX
  • County Down
« Reply #3 on: 11 December 2009, 22:24:22 »
I just replaced the aux belt a few months ago and while it was of I span the water pump and checked it for play and leaks etc.. and it seemed fine. Mind you I had drained the coolant before hand. Would that make any difference?
I was thinking it might be the oil pump, as that would explain why it gets louder when warm?
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 11 December 2009, 22:27:02 »
You should have replaced it when changing the aux belt
