Author Topic: h/seats  (Read 2009 times)
chelski
  • Eastleigh
h/seats
« on: 11 December 2009, 14:35:27 »
has any one fitted waeco heated seats if so could someone help with wiring
would be grateful
Darren
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: h/seats
« Reply #1 on: 11 December 2009, 15:43:40 »
You will probably find that the wiring loom is already present but tied up out the way. As far as I know the loom is the same, just some parts are not connected.
Might be wrong but worth a looky under the seats just in case.
Mine are GREAT!
pembroke
  • Suffolk
Re: h/seats
« Reply #2 on: 11 December 2009, 16:06:21 »
Mine are GREAT!
It was 3 degrees in Cambridge all day. I turned on my heated seats to 3 and was boiling! Am I the only one that finds the seats to be too hot when set above 2?  :-/
« Last Edit: 11 December 2009, 16:06:54 by pembroke »
amba
  • Medway towns
    • German V6
Re: h/seats
« Reply #3 on: 11 December 2009, 16:09:06 »
chelski...what issues are you having with the seat heaters?
All the wiring is complete with the waeco kit,needing only connecting to a +12 and earth.
My suggestion was using the existing wiring which is located by the multipoint connector on either side of each front seat.
chelski
  • Eastleigh
Re: h/seats
« Reply #4 on: 11 December 2009, 17:23:25 »
what i done now on original loom 2 wires 1 brown 1 red/black connected brown to red and orange to red/black and battery was already dead but when connected it drained what was left so i would imagine i got right this time because power going to them now from old switch
does that sound right now
darren
amba
  • Medway towns
    • German V6
Re: h/seats
« Reply #5 on: 11 December 2009, 17:31:37 »
That sounds correct...Vauxhall seem to use brown as 12volt +,so that should be connected to the Red wire from the kit....strange you have an orange wire as the set I got had a black wire,which does connect to the other side which is red/black.
Are you saying they work now but your battery is just flat ??
chelski
  • Eastleigh
Re: h/seats
« Reply #6 on: 11 December 2009, 17:36:24 »
well when connected the scart for old h/seat back in main loom it drained what was left out because door lights was dim but then faded out completely
darren
chelski
  • Eastleigh
Re: h/seats
« Reply #7 on: 11 December 2009, 17:37:29 »
oh yer in kit you have 1red and one orange and a ground wire
amba
  • Medway towns
    • German V6
Re: h/seats
« Reply #8 on: 11 December 2009, 17:40:29 »
So is it all working now,just the fact the battery is drained .
chelski
  • Eastleigh
Re: h/seats
« Reply #9 on: 11 December 2009, 17:42:44 »
i think so find out in morning but sounds correct now these omegas drive you mad but suppose keeps you busy
thanks for all the help
darren
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Re: h/seats
« Reply #10 on: 11 December 2009, 23:11:52 »
Hello all,can I say as far as I know VX have always used the brown wire as - (negative) return to ground. Regret connection as you describe could possibly have blown fuse No14. :-/
