Author Topic: Steering Geometry - any recommendations  (Read 2015 times)
A Baked Bean
« on: 06 December 2009, 23:22:55 »
Hi,
looking for any recommended garages that can cope with the Omega set-up.
Can either be Central Scotland up to Dundee, or North West down to Manchester/Liverpool, or North East to Durham.
I do lot of driving down/up to these area's so any would do.  :D :D :D
thanks
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Steering Geometry - any recommendations
« Reply #1 on: 07 December 2009, 05:37:16 »
how bad is it?
omega6
  • Midlands
« Reply #2 on: 11 December 2009, 09:46:09 »
Hi,
thanks
I would try a body shop, and ask them to do an optiflex, its more expensive than standard tracking, bout they will adjust all 4 wheel geometry. most reputable bodyshops will do  it and charge approx £60
davethediver
  • Blackburn, Lancs.
« Reply #3 on: 11 December 2009, 12:20:43 »
WIM is a bit far down for you me thinks (Chesham), there is a place in bolton that quite a few up this way use i forget the name but will have a look for you  :y
P.A. Caron de Beaumarchais
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #4 on: 11 December 2009, 19:36:49 »
That'll be Nigel Langs. clicky
TuBy's new whipping boy.
davethediver
  • Blackburn, Lancs.
« Reply #5 on: 11 December 2009, 19:40:21 »
Thats the one couldn't rember the name of it cheers Captain  :y
Taking mine there once ive changed the bearings and a few other parts :(
KillerWatt
« Reply #6 on: 11 December 2009, 20:30:53 »
Any tyre bay that has the Hunter 4 wheel alignment kit will do you (that's all WIM use).
Just point out to the operator that he might want to tweak the front camber to -1' 10'' (or as near as poss) to give your front tyres a slightly easier life.
Before you take it in, you might want to spray the various locknuts associated with adjustment with something like WD40 in order to make the operators life easier (for a good week beforehand).
wheels-inmotion
« Reply #7 on: 11 December 2009, 21:16:35 »
I use the Hunter DSP811 series and the modified car software so not the usual Hunter system.
A problem some may have is most garages will not deviate from the OEM settings so you need to check first.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #8 on: 12 December 2009, 00:14:03 »
WD40 will do it, or a specific releasing spray. I use Silkolene Silkopen. When it's sorted, a good coating of copper grease on the threads with a top up now and again should keep things moving freely.
I've just got back from WIM. 400 mile round trip, but worth it. The local geo folk don't use WIM settings.
« Reply #9 on: 12 December 2009, 16:11:52 »
Additionally, the operator needs to have an understanding of the interdepencies of the settings.
This is precisely why my cars only ever go to WIM, and have only been touched by Tony (even before the official formation of the company).  I'm lucky enough to only live around 75mins away though.
