Author Topic: Heavy steering  (Read 1485 times)
goonv6
Heavy steering
« on: 12 December 2009, 18:00:34 »
My car has just developed heavy steering.I know that the idler arm is in need of doing and I have a brand new genuine one to pop on this weekend but surely it can be that? The fluid level is right, the serpentine belt is new, the pump has only done 55k. Is my rack on the fritz? (That's doneŁ150k) :question
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Heavy steering
« Reply #1 on: 12 December 2009, 19:24:25 »
are your tyers up to pressure, is your fluid upto the top mark, do you know when it was last changed (fluid), it could be your belt slipping.
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
Re: Heavy steering
« Reply #2 on: 12 December 2009, 19:45:48 »
or it could be a fuse - there was a recent post regards that & i know by my own experience. check your cig lighter i think its the same fuse.  :y
goonv6
Re: Heavy steering
« Reply #3 on: 12 December 2009, 21:19:33 »
Cigar lighter working,belt and tensioner new, Fluid is brand new and tyres up to pressure. Hmmpphhh! :-/
« Last Edit: 12 December 2009, 21:20:03 by goonv6 »
Re: Heavy steering
« Reply #4 on: 12 December 2009, 22:02:43 »
So, fuse 14 is ok.....is it any better if you rev the engine?
Is the speedo working ok?
