Author Topic: Another heater problem  (Read 1230 times)
« on: 12 December 2009, 17:22:48 »
Odd one this ... On startup in the morning the system will always work fine, obviously once the coolant has warmed up, giving plenty of heat.
Intermittently over the past couple of weeks I've had a problem that after switching off, to pop into shops, refuel, whatever.... after restarting I only get cold air.... doing a system reset makes no difference.
Doesn't always happen but is happening more often.
I'm thinking perhaps the HBV is "sticking" internally once warm ... but I can't see why it would stick in the "cold" position as it would have been in the "hot" position when the engine was switched off .. if that makes any sense ...  :-/ :-/
Anyone any other ideas ???  Before I rip my hands to bits changing the HBV ??
    • 530D M Sport, 330i Coupe
Re: Another heater problem
« Reply #1 on: 12 December 2009, 21:23:38 »
Think it's more to do with the vacuum state rather than the previous heat mode.
When I changed the HBV on my current 3.2 it wasn't particularly difficult. Just took the scuttle off, unclipped and pulled the HBV to the offside, no grazed hands etc.
« Reply #2 on: 12 December 2009, 21:36:41 »
I guess I didn't explain my self too well......
Vacuum at the HBV gives COLD, no vac gives HOT  or so I believe.
So with hot selected and no vac applied, when you switch the engine off there is no force to move the HBV.  When you start the engine and ask for cold, vac is applied to move the HBV.
I would therefore expect it to "stick" in hot not cold  ??
Unless of course there are springs inside it doing things I know nowt about !! which destroys my theory instantly !! I'm assuming any springs bias it to the no vac hot position.
I guess the answer is to change it and see ... a new HBV is a lot less than a climate panel !!!
« Reply #3 on: 12 December 2009, 21:48:15 »
Entwood, I have a brand new climate panel still in delivery mode, I bought it to replace the worn out buttons on mine, so it is minus the buttons and would need to be programmed, but if yours is found be Fubared, give me a PM, you can have it for the price of a new HBV :y
« Reply #4 on: 12 December 2009, 21:56:33 »
Noted thanks ...  :y :y :y :y
I'll go the HBV route first as its probably easier :)
Work list building up now ..
HBV
Cam cover gaskets
Breathers
Oil & Oil filter
Pollen filter
Wiper Blades
Fix the damaged wing
just need some dry days to coincide with not-working days .. :(
Abiton
« Reply #5 on: 12 December 2009, 22:09:45 »
If you haven't already tried it, why not run it for a few days with HBV vac hose disconnected and plugged.
If the strange behaviour goes away, you'll know that it's control of vac states in the cabin system that's at fault.
I'm not too sure how your particular symptoms could arise w.r.t. solenoid valve misbehaviour or whatever, but it would be a shame to change the HBV and still find the same thing happening.
« Reply #6 on: 12 December 2009, 22:20:15 »
Thats not a bad idea ....   :y :y :y :y :y
