Author Topic: Paperclip codes 144 and 59 on 2.5 V6  (Read 927 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 13 December 2009, 17:18:25 »
Finished cleaning breathers. Put it back together. second test run put my foot down going up a steep hill and Phtt plus EML on so immediately lifted off. Car still runs fine in fact better than it has for years probaly due to the two small breather pipes having had splits in them. No smoke, nothing obviously disconnected.
Codes are 144 and 59.    Immobiliser faulty wiring or no signal (low battery in key fob not had time to get a new one? or car battery was disconnected during work?)  59 Inlet manifold valve 1?
Any ideas gratefully received at this Yuletide time.
varche
« Last Edit: 13 December 2009, 17:24:07 by olive »
Re: Paperclip codes 144 and 59 on 2.5 V6
« Reply #1 on: 13 December 2009, 18:25:22 »
Is the rear multiram connected up?
Varche
    • Golf Estate
« Reply #2 on: 13 December 2009, 19:07:18 »
Priceless. I had forgotten the rear connector. Thanks a lot Mark.
Varche
sparten
  • ffoss-y-ffin,near aberaeron
  • usually,fixing his miggy
« Reply #3 on: 13 December 2009, 22:14:28 »
christ your good you should work fo vx they might know whats going on under a bonnet then  :)
