Author Topic: Tyre Pressures Please.  (Read 1715 times)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« on: 13 December 2009, 21:14:50 »
Could someone please confirm the correct type pressures fo my 3.0 Elite running with 235/45/17 elcrapo tyres.
I didn't get a manual with the car.
Re: Tyre Pressures Please.
« Reply #1 on: 13 December 2009, 21:20:11 »
Doesn't cover everything but is useful as a reference ...
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
Page 225 for tyre pressures .. but I've just noticed .. nowt listed for the 3.0 at all !!!!
« Reply #2 on: 13 December 2009, 21:23:55 »
..... .. but I've just noticed .. nowt listed for the 3.0 at all !!!!
I'd think tyre size would be more applicable than engine size!
I'm glad you posted the link cos I'd managed to  lose it :(  ;)
« Reply #3 on: 13 December 2009, 21:26:59 »
I think they use engine size as the "common denominator" of vehicle weight ... which is what the air pressure in the tyres supports   :)
If it wasn't bloody freezing and I've got me slippers on .. I'd pop out to the car and check my handbook ...  :)
« Last Edit: 13 December 2009, 21:28:17 by entwood »
« Reply #4 on: 13 December 2009, 21:42:03 »
Wus!!  ;D  ;D  ;D  ;D
My hand book (wich is placed conveniently next to me at the PC  ;)) says 30 / 33 up to 3  persons  and 39 / 45.7 psi with full load.  :y  :y
« Reply #5 on: 13 December 2009, 22:19:52 »
run mine at 33 with the same wheel size and 3.2 saloon. Depending on tyres, use and feel, usually 30 to 34 for most people i guess? :-)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #6 on: 13 December 2009, 22:38:48 »
Thank you guys...thats great.
« Reply #7 on: 13 December 2009, 22:46:07 »
Wus!!  ;D  ;D  ;D  ;D
Apparently .. as I'm southern I'm allowed supposed to be one .. :)
« Reply #8 on: 13 December 2009, 22:48:33 »
Wus!!  ;D  ;D  ;D  ;D
 ;D ;D ;D ;D ;D :y :y
« Last Edit: 13 December 2009, 22:48:55 by Andy_B »
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #9 on: 14 December 2009, 03:12:34 »
« Reply #10 on: 14 December 2009, 17:23:18 »
This site may help http://www.priamittyres.com/inflation_pressure_chart1.html
Doesn't list the common tyre sizes on Omegas - eg 235/45/17 or 225/55/16.
Only lists sizes available in Kampala, Uganda!!
Try a more modern and accurate UK one - http://www.dunlopdriversclub.co.uk/tyres/search/vehicle/  :y
« Last Edit: 14 December 2009, 17:23:52 by dbug »
rustym95
« Reply #11 on: 14 December 2009, 21:58:15 »
i dont have them size's, it was on board at local tyer fiters
« Reply #12 on: 15 December 2009, 00:10:14 »
What size are yours then?
Another reference for Vx tyre pressures by model can be found here - http://www.thetyrepressuremonitor.com/tyrepressures_vauxhall2.html
rustym95
« Reply #13 on: 15 December 2009, 02:11:23 »
215/65R/15/96H rear, 195/65R/15/91V frunt standard rims
38psi rear 34psi frunt.
