Author Topic: Does anyopne have a Crank Sensor for a 2.5 TD  (Read 1219 times)
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« on: 14 December 2009, 12:21:45 »
I have just found out that there are only 2 Crank Sensors (Vx bit) within Europe.
I have PC'd it and have Code 19 and Code 64, both of which I would consider could give me starting issues.
Help...
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Does anyopne have a Crank Sensor for a 2.5 TD
« Reply #1 on: 14 December 2009, 15:39:45 »
Help...
try these
http://www.carpartsconnexion.com/vauxhall/searchresults.asp?f=Vauxhall&m=OMEGA&y=Any+year&cat=0&d=&p=&q=sensors :y
patriotste
  • Stockport
« Reply #2 on: 14 December 2009, 19:39:00 »
Hello,I have a brand new Bosch one for the 2.6 petrol,not sure if it is the same for the TD. The part number is  0261210131 cost me £50 but will take £30
davo
« Reply #3 on: 15 December 2009, 16:19:01 »
hi i have a second hand crank shaft sensor for a 2.5td, if your interested, i bought it from a breakers a fwe months, but didnt cure my fault, cost me £25.00 if you want it txt me 07900075366, if you want i can list it on ebay, or whatever way you want to do it, thanks,,,davo :D
« Reply #4 on: 15 December 2009, 20:55:05 »
I may have one in the garage. If still there, you can have it.  I can't remember if I've already given it away (its my age!)
