Author Topic: Re: dose any one no the part number  (Read 1710 times)
« on: 15 December 2009, 11:38:00 »
Is it pictured here
« Last Edit: 15 December 2009, 11:38:41 by RobG »
« Reply #1 on: 15 December 2009, 11:46:12 »
I need the part number for the sterring idler fixing, you know you bolt the idler on to it, as past mot but say that part needs changing as worn out. thanks
How the hell that bit wears out I dont know!
« Reply #2 on: 15 December 2009, 11:47:35 »
Welcome to "rustyspeak" ;D
andyc
  • Norfolk
« Reply #3 on: 15 December 2009, 12:39:21 »
i think you are looking at number 14, part number 90445587 @ £58.56 + VAT.
Cheers
Andy
Thetford. Norfolk
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #4 on: 15 December 2009, 14:30:58 »
Is it pictured here
number 14, mot'er says it worn out and needs replacing.
rustym95
« Reply #5 on: 15 December 2009, 22:03:26 »
thanx for help getting part from vauxhall whitby £8.50 with vat. :y
Big_Roger
  • Southampton
« Reply #6 on: 15 December 2009, 23:08:35 »
Hi
I think it is part no 12 on diagram, which comes complete with the bearing fitted in it that wears.
Just ordered one:
Steering idler arm 9195731 from Vauxhall Parts Warehouse £29.95 +p&p
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
rustym95
« Reply #7 on: 15 December 2009, 23:12:08 »
Hi
Just ordered one:
Roger
thanks m8 have new idler it was the number 14 bit, he past car as he ( MOT'er) know i will get it fixed.
& £8.50p is not bad.
    • 530D M Sport, 330i Coupe
« Reply #8 on: 15 December 2009, 23:14:54 »
Apparently it's not the idler arm (the common failure) it appears to be part 14 that isn't known to wear....  :-X
rustym95
« Reply #9 on: 15 December 2009, 23:19:58 »
he said it, even showed me he said that they wear out from rubbing left and right and it has not done to bad as the idler was the original one from new, can see the rings on it when he tuck off the idler and showed me. said when you get a new idler should get the kit come with every thing.
« Reply #10 on: 16 December 2009, 01:44:32 »
Thought on an MOT they were not allowed to dismantle anything  :o :-/
rustym95
« Reply #11 on: 16 December 2009, 01:46:59 »
after the mot what are you. ive know him for over 5years good bloke.
« Reply #12 on: 16 December 2009, 01:51:45 »
?? not psychic - you didn't say that in your post
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #13 on: 16 December 2009, 05:43:37 »
He is correct - the MOT tester is not allowed to dismantle anything.
Its part number 14 on the pic but to be truthful I have never known one to wear. For that part to wear there must be something else very amiss in your steering linkage. The Idler itself that locates on it is a common wear problem though. Changed it on mine the first time at 152000 miles. The clone I fitted first to save money lasted 7600!
Why not just buy a new genuine VX Drop Arm Idler, fit it and then try it for movement? Do not buy an aftermarket clone that WILL fail rapidly and leave you back at square one like I did the first time.
Do it yourself, its really easy (takes about 30 mins) and I think you will find that it solves your problem.
GudLuk
« Last Edit: 16 December 2009, 05:51:44 by its.ray »
rustym95
« Reply #14 on: 16 December 2009, 05:53:34 »
Its part number 14 on the piuc but to be truthful I have never known one to wear. The Idler itself that locates on it is a common wear problem though.
GudLuk
it is a genuine idler, it is the top part of the shaft on 14 gone worn out the shaft as it has had the original ldler on for 14 years nearly 15 years in feb 2010, its had its time.
