Author Topic: x25xev fault  (Read 967 times)
alenalper
  • Istanbul
x25xev fault
« on: 16 December 2009, 15:00:32 »
2 weeks ago i bought my second omega , its 97 model and x25xev , i have several problems
1-When i made paperclip test, i have 13-135-46-87-48-31 and 144 codes.
most importand is 31-87 , i checked and cleaned crankshaft sensor ,and normally rpm is not working , and heater is not working too.It does not blow out.All fuses are okay.Opel garaga says that ,because of n
o rpm signal heater fan is not blowing out ??.Engine is working fine ,only no rpm and no blow out.Frozen in the car since 2 weeks.What do you recommend ?? What should i do to solve these problems..
And,, 87 =A/C Cutoff Relay Voltage Low
Thnx already..
« Last Edit: 16 December 2009, 15:28:26 by alenalper »
SUZUKI
GSXR 1000
K6
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: , bought
« Reply #1 on: 16 December 2009, 15:03:38 »
ive seen a engine that had them codes and it was the ecu at fault but could be wrong.
