Author Topic: Coil pack???  (Read 2475 times)
bertiecbx550
Coil pack???
« on: 15 December 2009, 17:03:36 »
I was on the motorway this afternoon and went to overtake a volvo and the miggy started to run a bit rough and struggle...Do you reckon it might be the coil pack and ht leads on the way out? Any idea how much they are? thanx folks.... :y
Re: Coil pack???
« Reply #1 on: 15 December 2009, 17:09:56 »
do a paperclip test first off, then check the condition of the plugs and see if any oil in the wells
« Last Edit: 15 December 2009, 17:10:20 by tunnie »
bertiecbx550
Re: Coil pack???
« Reply #2 on: 15 December 2009, 17:11:48 »
Hope it aint the crank sensor again though  ;D ;D ;D :o
Tony H
  • liverpool
  • Black Elites are luurvley
Re: Coil pack???
« Reply #3 on: 15 December 2009, 18:48:32 »
Look for any other fault codes other than dis pack as a faulty one will not show a code
Re: Coil pack???
« Reply #4 on: 16 December 2009, 07:58:29 »
Assuming a genuine one was used then its unlikely, if some cheap aftermarket part was used, its quite possible
bertiecbx550
Re: Coil pack???
« Reply #5 on: 16 December 2009, 23:31:56 »
Well i managed to do the paperclip test and guess what??? No codes being thrown up not even cranksensor....So as long as it dont get anyworse i`ll live with it till payday and then hunt for a dis pack and new ht`s and plugs i think.....Heres to crossed fingers and toes and other things that can be crossed.... ;D ;D :o
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Coil pack???
« Reply #6 on: 17 December 2009, 02:03:28 »
could be the air filter or fuel filter they would make it try to cut out. not getting fuel or air fast enuf.
Re: Coil pack???
« Reply #7 on: 17 December 2009, 10:04:14 »
Never seen that yet....
mathewst
  • Split, Croatia
    • v40
Re: Coil pack???
« Reply #8 on: 17 December 2009, 10:11:46 »
According to the some posts in general questions on of the admins said that actually air or fuel filter can make a big difference. Not sure which one though
Re: Coil pack???
« Reply #9 on: 17 December 2009, 10:14:41 »
It can restrict the fuel flow, and hold back revs, but its slight. When i changed mine, it reved a lot more 'freely' easily getting towards the red line.
I can't see it cutting out  :-/
My old fuel filter was very old AND mounted the wrong way!  :o
I'd be checking the condition of the plugs, and oil in the wells as stated previously
trainastock
  • st neots  cambridgeshire
Re: Coil pack???
« Reply #10 on: 17 December 2009, 21:57:16 »
sorry to hear of your problems  :(,on the last service i had changed ,the air filter ,fuel filter , spark plugs , also all gasket rings etc with vauxhall parts , i think i was told that the  ht leads would need changeing on next service
bertiecbx550
Re: Coil pack???
« Reply #11 on: 17 December 2009, 22:27:39 »
Dont worry bout it graham it aint your fault mate... Things wear out as time goes on,i`m happy with the miggy i forgot what a pleasure these cars are to drive and you put a lot of effort into this motor its just 1 of those things :y :y
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
Re: Coil pack???
« Reply #12 on: 17 December 2009, 22:40:20 »
When I changed my plugs there was some oil around them & the bottom of the coil pack, whats that all about.
The old plugs came out VERY easy but could not torque my new ones up to18foot/pounds, got scared! :-?
