Author Topic: Couple of questions from a newbie  (Read 1628 times)
mick11
  • Driffield, East Yorkshire
« on: 16 December 2009, 15:07:57 »
Couple of questions.
Anyone know of a user manual for the "My Naff Code Reader" diagnostic tool, and normal readings/settings for my 1999 2lt CD auto. It seems to work ok and shows no fault codes. Would be nice to know what the other reading mean, some are self explanatory but not all.
The drivers door strap just flops about and does not attempt to keep the door open.Is this controlled by the plastic bush in some way.
Mick
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Couple of questions from a newbie
« Reply #1 on: 16 December 2009, 15:12:26 »
from op- com or on dvd or cd  help file depending on what version disc is,
« Last Edit: 16 December 2009, 15:13:01 by Russell_Hill »
Omega's is a life not just a car. also do ecu codes read and wiped or rest.., fix LCD tv & DVD recorders PS3's and most electrical equipment just e-mail me.
« Reply #2 on: 16 December 2009, 15:21:02 »
Mick
The check strap will have ripped itself from the leadin edge of the door. Have a read here .......  :y http://www.omegaowners.com/forum/YaBB.pl?num=1152902108
mick11
« Reply #3 on: 16 December 2009, 15:39:31 »
No nasty noises and plates look to be ok. From what I can see from pics the bush looks as if it it applies pressure to the arm and holds it in contact with the plates, is this correct. Dont want to rip the door apart unless absolutely necessary.
« Reply #4 on: 16 December 2009, 15:47:32 »
No nasty noises and plates look to be ok. From what I can see from pics the bush looks as if it it applies pressure to the arm and holds it in contact with the plates, is this correct.  .....
Not really! The plastic bush is just to 'soften' the hinge pin on the A post. If the stay is 'flopping about' it'll be because the door (picture 3) is ripped and ithe strap isn't fastened to anything ......... Obviously I can only guess cos I'm here & you're there!  :y
mick11
« Reply #5 on: 17 December 2009, 10:51:21 »
Thanks, it can wait till better weather next year in that case.
From what you are saying there is some sort of mechanism that fits on the end of the strap inside the door, any pics of this anywhere that anyone knows of.
Mick
tony2
  • peterlee north east
    • 2.6 cdx auto
« Reply #6 on: 17 December 2009, 22:19:23 »
had same problem last year with wifes 99 2ltr auto  bought repair kit took door of fitted kit door back on all in 30mins worked perfect :)
« Reply #7 on: 17 December 2009, 22:43:15 »
Mick
Yes! In my case it was lying in the bottom of the door.  :'(
RobG
    • 16 plate Mokka. Vivaro
« Reply #8 on: 17 December 2009, 22:56:57 »
Mick
mick11
« Reply #9 on: 18 December 2009, 08:09:59 »
Many thanks to all for help. Pics really useful  :y
Mick
