Author Topic: 1997 2.5TD AUTO PROBLEMS  (Read 1390 times)
gotchya1
  • llanelli carmarthenshire,wales
« on: 18 December 2009, 15:11:23 »
HI I RECANTLY BOUGHT MY OMEGA AND LOVE THE CAR DEARLY BUT THE AUTO BOX SEEMS TO BE UNSURE OF HOW AND WHEN TO CHANGE GEAR,BUT THIS PROBLEM CAN STILL BE FELT UP TO 80MPH IN TOP GEAR,
IT SEEMS TO ME IF THE GEARBOX IS HOLDING THE ENGINE BACK,
SOMETIMES MISSING GEAR ALTOGETHER WHEN I SELECT DRIVE
IT FEELS LIKE THE CAR BRAKES SUDDENLY FOR A SPLIT SECOND
AND THE FEELING IS WORSE WHEN THE CAR IS UNDER LOAD LIKE CLIMBING A BIG HILL,,
IM HOPING ITS JUST A CASE OF NEEDING TO CHANGE THE GEAR OIL OR MAY BE THE AUTO MODULE,,
BUT ANY HELP IS MUCH APPRECIATED
...G.... ::)
Re: 1997 2.5TD AUTO PROBLEMS
« Reply #1 on: 18 December 2009, 15:18:51 »
1st things 1st ... caps lock is the third key up (middlerow) on the very left of the keyboard ... does not need to be set.
Typing in CAPITALS IS CONSIDERED SHOUTING ... :)
Having sorted that you can start on the car .... 2 common problems are the fluid level and the selector.
Fluid level checks here :
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
There isn'y a "guide" to cleaning the selector .. but a forum search will find several threads discussing it.
This one is how to remove it ..
http://www.omegaowners.com/forum/YaBB.pl?num=1251389016/3
And ... Welcome to the forum ...  :y :y :y :y
HTH  :)
« Last Edit: 18 December 2009, 15:22:20 by entwood »
Stevie-blunder
  • Wolverhampton
« Reply #2 on: 18 December 2009, 19:20:58 »
Entwood's right, most likely it's the ATF, check and top up or change it. Should do the trick  :y Mine had a problem very similar and after a top up was perfect, check for leaks as well. ATF gets quite hot in use and the mechanic that done mine said it was probably the first time it had ever been checked and had got low with 10 years use.
gotchya1
« Reply #3 on: 18 December 2009, 19:43:23 »
Sorry about the caps lock ::) lol
and thank you very much for the advise and helpfull hint
and a big thanx for the welcome,
....G.... :y :y
