Author Topic: Rubber weather strip  (Read 1083 times)
Nickbat
« on: 20 December 2009, 19:44:52 »
Driver's door was frozen shut today. Gave it a bit of a yank and it opened.
..Unfortunately, that action seems to have caused the bottom weather strip to come a bit loose.  ::)
I can't see well as it's dark now, but it seems to have come off two rivets or similar.
Can I just clip back on, or will I need superglue...or a new weather strip?
Anyone else had a similar problem in this weather?
Re: Rubber weather strip
« Reply #1 on: 20 December 2009, 22:01:37 »
Yea mine was stuck - poured warm water down sides of door to minimise risk of b*ggering door seal  ;)
Dried seal off and smeared with a touch of vaseline to assist next time  :y
« Reply #2 on: 20 December 2009, 22:19:18 »
The straight bit along the bottom?
It is as you suggest, clipped onto a rivet welded to the car. They just clip back on. silicon spray also helps to prevent the door from freezing shut.  :y  :y  :y
« Reply #3 on: 20 December 2009, 22:39:05 »
i had problems opening the back doors on the car this morning, they never get used, but were frozen solid this morning. Almost ripped the door handle off opening the door  ;D
Nickbat
« Reply #4 on: 20 December 2009, 23:40:30 »
Thanks, Andy. I fell happier now! :y :y
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #5 on: 21 December 2009, 01:54:06 »
All my doors frozen shut this morning, I had to get the wifes kitchen blow torch on the boot lock to open the boot as the button had frozen...   Me thinks the locks need to be introduced to a little WD-40... lol...
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #6 on: 21 December 2009, 02:57:07 »
Best thing to use is a silicon trim spray, there are loads of them about and work brilliantly even in the coldest weather. I used it on my coach in north Norway at -25 and the side lockers and boot lid seals always stayed free from ice sticking them to the doors. I use it on all of my trim on a weekly basis now anyway.
One word of warning though! Do not get any on any glass cos its nigh on impossible to get off. One bright t**t said it coulkd be used on the windscreen to stop it icing up too so I gave it a go and regretted it. I ended up using raw cellulose thinners to get rid of it.
Rubbers definitely YES. Glass certainly NOT.
GudLuk
Page created in 0.024 seconds with 16 queries.
