Author Topic: Outside Temp Display  (Read 2189 times)
Londonflyer
  • Botley, Oxford
« on: 12 December 2009, 16:58:52 »
My display is showing 45.6c and it was 9c outside. can anyone tell me how to fix the problem? i have a year 2000 2.5 CDX
Any help would be very welcome...
David
pembroke
  • Suffolk
Re: Outside Temp Display
« Reply #1 on: 12 December 2009, 17:02:12 »
9 degrees celcius is 48 degrees fahrenheit. Sounds like the display needs to be changed to read in celcius; have you checked your owners manual?
pembroke
  • Suffolk
« Reply #2 on: 12 December 2009, 18:32:15 »
Just looked in the manual; press the auto button on the climate control and hold in for about 3/4 seconds, this will change the display from F to C
  • Auckland
    • Mazda MPV
« Reply #3 on: 12 December 2009, 19:02:36 »
IIRC this doesn't alter the display of outside temperature.
Previous discussions on this issue seem to have concluded that Tech2 is required to set F or C on the MID.
As the display is showing C the problem is likely to be corrosion of the electrical connector on the temperature sensor under the bumper (or a faulty sensor).
« Reply #4 on: 12 December 2009, 19:14:19 »
The reported "fix" of pressing auto on the CC will change the CABIN SELECTED TEMPERATURE on the CC between C & F .. it will NOT affect the MID in any way, shape, or form ....   :)
Tim7
  • Wiltshire
« Reply #5 on: 12 December 2009, 21:15:34 »
Had a similar thing with mine some time back, it was showing -35 to -45 then going up and down, checked the sensor on the front bumper the tip had been broken off, got a new one from the scrappy all working problem fixed, may be worth checking yours, HTH :y
« Reply #6 on: 12 December 2009, 21:31:03 »
....., got a new one from the scrappy all working problem fixed,  .......
A brand new sensor is only around 6 from Vauxhall.  :y :y
Londonflyer
  • Botley, Oxford
« Reply #7 on: 13 December 2009, 23:36:50 »
where can i find the sensor?? i have a year 2000 2.5 omega
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« Reply #8 on: 13 December 2009, 23:40:38 »
Its attached to the under side of the front bumper, passenger side I think
Welung666
« Reply #9 on: 14 December 2009, 02:08:16 »
2000 will be a facelift. Sensor is in the centre of the bumper. Open your bonnet and look down the front of the radiator and you'll see it :y
JesterRT
  • Stafford
« Reply #10 on: 14 December 2009, 13:16:44 »
My display would start gradually counting up to a very high outside temperature.  My fix?  Hit the CC panel.  Happened twice and then never again in the year or so that I owned the car.
Perhaps a poor connection on the CC panel?  Not the method I'd recommend to 'fix' it (as I guess it could have broken more things) but one good thump with the palm of me hand seemed to get things going again.
Londonflyer
  • Botley, Oxford
« Reply #11 on: 21 December 2009, 10:47:01 »
Thanks guys! All sorted now. Sensor cost me £6. and 1 min to fit... Hope you all have a good Xmas and New Year!!!!
