Author Topic: Remote Key  (Read 1030 times)
keith777
Remote Key
« on: 21 December 2009, 11:59:29 »
I have a broken key , can anyone tell me how to get a new one Key No 105
Re: Remote Key
« Reply #1 on: 21 December 2009, 12:04:55 »
key number is of no use really. We need a bit more information, as key design changed over the years which changes what needs to be done
How old is the car? Do you have a 'bubble' near the sunroof switch? - If Yes then its the IR system and a replacment fob needs to be linked to the car.
If you have the later radio type, then you need the 'car pass' which is credit card size peice of paper which has details on the car, which you need to take to a dealer to have a key programmed to the car with tech2.
Might be worth posting up your location, as we may have tech2 near you...
eBay is your best source for replacement blades & fobs, then just take to a local cutting shop
Was that friendly enough?  ::)
« Last Edit: 21 December 2009, 12:06:58 by tunnie »
Re: Remote Key
« Reply #2 on: 21 December 2009, 12:07:47 »
When you say "broken" .. how exactly ...?? In snapped or "not working" ??
If it's the latter .. then PM Martin Imber on the site ... he repairs electrically failed keyfobs ... :)
HTH
keith777
Re: Remote Key
« Reply #3 on: 21 December 2009, 12:10:28 »
Its not the remote thats the problem its the key metal part thatb is broken and I have another no HO301 Keith
Re: Remote Key
« Reply #4 on: 21 December 2009, 12:14:07 »
Are the buttons to the doors integral to the key (not on a seperate fob?)
If thats the case and you have a replacement blade, get it cut, and re-fit, but remember to transfer the transponder
Re: Remote Key
« Reply #5 on: 21 December 2009, 15:13:39 »
105 is the blade type. Buy another 105 blade, and use the tranponder and remote from your old key
keith777
Re: Remote Key
« Reply #6 on: 21 December 2009, 18:03:17 »
Thanks all Bought new blank 105  Im told I can get it cut  at a good locksmith
Re: Remote Key
« Reply #7 on: 21 December 2009, 18:24:43 »
yes you can, some key cutters are just lame, just take the transponder out and say you will sort the programming
« Last Edit: 21 December 2009, 18:24:53 by tunnie »
