Pages: 1 [2] 3  All   Go Down
Author Topic: rattling like a good un  (Read 4507 times)
Re: rattling like a good un
« Reply #15 on: 19 December 2009, 10:00:50 »
Sounds more like a sticky lifter :-? :-? :-?
update paul, doesnt make any noises until it fires up, no noise when its wound over. this points to the lifters to me, what do you think.?
Could be. Does it sound as bad as the green one did when running?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #16 on: 19 December 2009, 11:47:26 »
is it one or both sides ?
if you let it run, does the tone of the noise change as the oil warms up ?
p j morgan
  • nottingham
« Reply #17 on: 19 December 2009, 14:16:11 »
sounds like you have a blocked oil feed pipe jon is it on both sides ? :-/ :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #18 on: 19 December 2009, 17:34:01 »
its a heavier noise than the green one was, darent leave it running long enough to hear which side.
« Reply #19 on: 19 December 2009, 18:35:34 »
My money is on the cambelt belt timing being out :(
The Red Baron
« Reply #20 on: 19 December 2009, 19:04:32 »
yeh, will have a look tommoz, been too busy today, out with the daughter to great central railway to see santa ::)
« Reply #21 on: 19 December 2009, 19:09:45 »
A pint says it's the lifters :)
I'd drop the oil for some fresh, pop a new filter on, and let it run up to temperature.
2.6 seems the most prone, in my experience, for some reason!
The Red Baron
« Reply #22 on: 19 December 2009, 19:13:13 »
i reckon a lifter too, will check cam timing in the morning & go from there i think. :y
The Red Baron
« Reply #23 on: 22 December 2009, 13:00:54 »
yep, you & me right. i thought the valves where having a conversation with the pistons. like 5 teath out :o. suspect this may be terminal :'(
i will fit new belt & tensioners & give it a go but not holding much hope tbh. :(
« Reply #24 on: 22 December 2009, 13:24:50 »
Bad news :(
One good thing though, at least James owes you a pint ::)
« Reply #25 on: 22 December 2009, 13:35:05 »
what let the belt slip? a tensioner?
« Reply #26 on: 22 December 2009, 13:35:46 »
Ouch, 5 teeth, aint gonna be pretty  :'(
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #27 on: 22 December 2009, 13:39:26 »
just a question how can the belt become 5 teeth out ? Mabey one of the rollers went bad or has frozen ?
v6 cam locking kit  member:y
The Red Baron
« Reply #28 on: 22 December 2009, 16:40:58 »
yeh the front left on the backplate. bummer :(
« Reply #29 on: 22 December 2009, 16:54:32 »
Bugger!  :'(
Was it a GM kit that was on it before?
Seeing a lot of failures recently, tensioner on mine got very, very noisey, only 27k old too  >:(
Pages: 1 [2] 3  All   Go Up
