Author Topic: fault code 64  (Read 2054 times)
hoofing it
fault code 64
« on: 22 December 2009, 18:09:31 »
Hi all Ive been browsing as a guest but I can't find anything on how to fix code 64 fuel quantity .the mechanic at my local garage isn't to clued up on fuel pumps.
I have a omega 2.5td on a x-plate
anyone any ideas.
Re: fault code 64
« Reply #1 on: 22 December 2009, 18:27:07 »
Try filling the fuel filter with diesel magic :y
hoofing it
Re: fault code 64
« Reply #2 on: 22 December 2009, 18:50:06 »
I think that was done two weeks ago the fuel filter was replaced as well he said he put the adative in the fuel filter apparently its whats done when the emissions are to high to clean the injectors and pump.
The treatmeant made a difference for a short time also the eml light flashes when you take your foot off the throttle and the mpg is horendous only getting 38mpg on a moterway run :'(
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: fault code 64
« Reply #3 on: 22 December 2009, 21:10:39 »
I get around 42mpg with roughly 30% town and 70% A roads.  M/way at 70-75mph gives around 48mpg. Does it happen less once fully warmed up. My EML did that with my original ECU.  I know it's not the pump as I've recently had it completely overhauled by a mate that's been a Bosch techie for almost 30 years.  Currently using a spare as I fried the original one when a booster starter lead slipped onto it.  Not doing it now. I'll ask whether it's ECU related when I get my BBQ'd ECU repaired.
On the Diesel Magic in the fuel filter issue, needing two or three doses isn't unusual.  :y
hoofing it
Re: fault code 64
« Reply #4 on: 23 December 2009, 08:07:36 »
Hi there the eml flashes most of the time even on the motorway and at low speeds
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
Re: fault code 64
« Reply #5 on: 23 December 2009, 11:30:08 »
i followed the advice on here and did the diesel magic trick a few times. something must of worked as i,m code free now.  :y
hoofing it
Re: fault code 64
« Reply #6 on: 23 December 2009, 14:24:45 »
Cheers chaps i'll give that a bash :y
