Author Topic: Headlight field/vision  (Read 2392 times)
Toe V6
  • Barrow-in-Furness
« on: 22 December 2009, 22:51:53 »
Hi, i was driving along tonight when the display told me to check headlight field/vision. Err...what does it mean? The headlights are still on, i know a foglight bulb has blown but they werent in use at the time. The cars a 99 elite estate 3L
  • Online Online
Re: Headlight field/vision
« Reply #1 on: 22 December 2009, 22:54:14 »
You've a fault with either one of the level sensors on the front nearside wishbone or rear nearside radius arm, or .... one of the level motors within either of the headlights.  :y :y You need a code reader to diagnose which.  ;)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #2 on: 22 December 2009, 22:54:52 »
Have a look here:
http://www.omegaowners.com/forum/YaBB.pl?num=1237989198
Trade club card holder
Code scanner available
« Reply #3 on: 22 December 2009, 22:55:53 »
Automatic headlamp height adjustment not working correctly.... as you have HID's .. :)
Possibilities ..
1) sensor has popped an arm ... 2 sensors ... one on front left wishbone, one on back rear suspension arm ... check them both
2) internal adjustmenbt motor/mechanism inside the headlights fubar ... don't think this is fixable .. needs a new headlight .. :(  ( I think .. hopefully wrongly )
« Reply #4 on: 22 December 2009, 22:56:32 »
There you go .. 3 answers at the same time .. :)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #5 on: 22 December 2009, 23:16:44 »
I ad that come up on mine last year and mine dont have that it turn'd out to be the motor on the light, tuck it off and sprayed it in the motor then it went away. dont know if that helps.
  • Online Online
« Reply #6 on: 22 December 2009, 23:20:46 »
Yours doesn't have what ..... ????  :-/
rustym95
« Reply #7 on: 22 December 2009, 23:37:01 »
level sensors
Toe V6
  • Barrow-in-Furness
« Reply #8 on: 22 December 2009, 23:54:16 »
Thanks all, i'll check in the morning :y
« Reply #9 on: 23 December 2009, 02:17:11 »
level sensors
If you haven't got level sensors how come you've got motors on your lights?  What controls them?  Are your lights HID?
« Last Edit: 23 December 2009, 02:17:36 by dbug »
mathewst
  • Split, Croatia
    • v40
« Reply #10 on: 23 December 2009, 08:44:10 »
If the lights are not hid level is controled by the potentiometer switch oposite to illumination switch of the instrument board. These lights also have motors
rustym95
« Reply #11 on: 23 December 2009, 15:05:16 »
yep.
« Reply #12 on: 23 December 2009, 15:19:10 »
I absolutely guarantee you you did not have that come up on a pre 1998 MID - the early MID doesn't have the functionality.  You may have seen it on a post 98 MID in another car :), and even then, only if:
a) MID misconfigured, so warning on all time
b) the headlight levelling ECU fitted to HID cars told post 1998 MID to warn driver of detected fault
« Reply #13 on: 23 December 2009, 15:20:19 »
As other said, check if the arm popped off on front and rear nearside suspension arms (front in particular), failing that will need code read.
« Reply #14 on: 23 December 2009, 21:09:21 »
Whoops - you're right, remember the system on a cd (company car years back!!) :-[
