Author Topic: Secondary air injection?  (Read 1709 times)
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« on: 24 December 2009, 00:42:02 »
Bit of a puzzler! How can I test the secondary air injection system?
How can I test the secondary air injection pump under the ns front wing to find out if the pump is working?
Looked in my TIS but cannot see it.
hotel21
  • The Kingdom of Fife
Re: Secondary air injection?
« Reply #1 on: 24 December 2009, 01:04:13 »
If its working, properly, you wont hear it!
If you hear it and it sounds like a 747 on its takeoff run, its already broken and needs unplugged.
If its already unplugged, its already broken!
Happy days!
Bottom line - its not worth bothering about.  If its problematic, unplug it and forget about it....   ;)
« Reply #2 on: 24 December 2009, 01:07:50 »
Happy days!
 ;D  ;D  ;D  ;D  ;D  ;D
Abiton
« Reply #3 on: 24 December 2009, 08:38:02 »
Take off the rubber pipe on the pump side of the flap valve.  Start the engine from cold.
If the pump's working you'll get a lot of air piling out of the end of the hose, if it isn't, you won't.
« Reply #4 on: 24 December 2009, 11:51:31 »
Do what I did, rip it out  ;D
« Reply #5 on: 24 December 2009, 12:06:36 »
H21 has summed it up perfectly!
Bionic
  • Leicester
« Reply #6 on: 24 December 2009, 12:10:55 »
Huh?
Sorry JamesV6-CDX but the way I run a motor is that if it is fitted then it should work and all parts used are the genuine article. Had too many problems with crap bits before.
Gave me a laugh though cos it is getting on my t**ts a bit now cos its too cold to do anything.
« Reply #7 on: 24 December 2009, 12:13:20 »
Huh?
You don't need SAI, all it does it help emissions on the first few seconds on start up, its not something to fix. Unplug and forget
« Reply #8 on: 24 December 2009, 12:18:15 »
I have bined it on any petrol Omega's I have owned infact Vauxhall got shut of it on the 2.6 and 3.2 ;)
Bionic
  • Leicester
« Reply #9 on: 24 December 2009, 16:13:37 »
Ok, If I get a look at it and it is working as it should I will keep it on. If its a problem I shall bow to those who have given good advice previously and let it die.
Cheers!
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #10 on: 24 December 2009, 16:18:46 »
get rid, im going to. as tb says, its like a 747 on take off. mine is ::)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #11 on: 25 December 2009, 00:55:17 »
mini makes a sound but its only the end bearing been like that for 3 years now but still works just not got round to changing the copper bearing and then change the bushes for the motor.
Bionic
  • Leicester
« Reply #12 on: 25 December 2009, 04:56:18 »
Strangely enough mine is completely quiet and after looking at it last night cos I got bored I found it to be working as it should.
As it should be there I will leave it alone until it needs attention. Looks like my concern was for nothing brought about by someones elses paranoia.
I will stick to my usual motto of 'if it ain't broke don't fix it'. Its always worked well enough for me in the past and after watching many of my m8t's constantly spending out on so called 'improvements and adjustments' I will keep my hard earned cash in my pocket. Looks like fiddling about when there is no solid reason to is an expensive and unproductive task to me.
Have great Xmas and a Greater new Year!
GudLuk all.
« Reply #13 on: 26 December 2009, 09:58:00 »
GudLuk all.
Yup - when working properly, you dont notice it.  As most of our cars are 9-15 years old (SAI not fitted to 2001 and later), a significant proportion of SAI pumps are knackered!
Page created in 0.039 seconds with 20 queries.
