Author Topic: V6 EGR  (Read 2350 times)
Re: V6 EGR
« Reply #15 on: 24 December 2009, 14:59:40 »
Just pull off the top radiator hose (it's got to come off anyway!) The 'stard bolt is then securing the pipe that you pulled the rad. hose from. (and the dipstick tube)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: V6 EGR
« Reply #16 on: 26 December 2009, 09:33:37 »
The Bastard Bolt holds the Dipstick, Transfer Pipe and the Engine Lift Bracket.
If you look for the engine lift bracket on the passenger side Tunnie and run your hand under it you will feel a bolt, that is it.
If you kneel with your eye level on the top of the passenger wing you should just be able to see it. :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: V6 EGR
« Reply #17 on: 26 December 2009, 09:36:37 »
still cannot see it, got enough trouble getting hand in there. This one is for a garage, its going back together.
Tunnie you should have no trouble getting your Chicken Wing arms in there  ;D ;D ;D
Re: V6 EGR
« Reply #18 on: 26 December 2009, 12:36:23 »
half the darn trouble is i could not see the bugger, its back together now, needed it yesterday. But it does need doing, temp sat at 75, unless i did 90mph then it sat at 80 on the temp.
That suited me fine  ;D
