Author Topic: V6 EGR  (Read 2360 times)
V6 EGR
« on: 24 December 2009, 11:23:33 »
Its been a while since i worked on the V6 lump, but i remember when taking the 22mm for the EGR pipe off, the pipe itself should just fall away, this one feels like its jammed in?  :-?
I've taken the nut off, but the damn pipe won't move.
Piccy:
« Last Edit: 24 December 2009, 11:24:03 by tunnie »
Re: V6 EGR
« Reply #1 on: 24 December 2009, 11:27:01 »
correct, as you already removed torx bolt to bracket.  The egr pipe wont move much, but as you lift plenum off, should break away
Re: V6 EGR
« Reply #2 on: 24 December 2009, 11:28:56 »
Ta, back to it then, could have sworn on your 2.5V6 project it just used to fall out, but maybe that was because we had the plenum off about 1000 times  ::)
  • Auckland
    • Mazda MPV
Re: V6 EGR
« Reply #3 on: 24 December 2009, 11:29:19 »
I think the nut pushes an olive into the tapered socket in the EGR.
Tapping the stainless steel pipe from side to side (gently so as not to damage the pipe) should free it.
Re: V6 EGR
« Reply #4 on: 24 December 2009, 11:31:44 »
give it a bit of a wiggle to help break seal on it
Re: V6 EGR
« Reply #5 on: 24 December 2009, 11:50:14 »
whooo plenum off, felt solid, but bit of brut force and it was off  :)
Before i take the inlet manifold off i thought i would find this 'b@astard' bolt, but where is it?
I have located the main feed pipe from the rad, do i have to take this off for the bolt to present itself?
Re: V6 EGR
« Reply #6 on: 24 December 2009, 12:05:35 »
founf memory, think it hold dipstick to block
Re: V6 EGR
« Reply #7 on: 24 December 2009, 12:07:04 »
so that coolant pipe needs to come off? - As i can't see the bolt anywhere  :(
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: V6 EGR
« Reply #8 on: 24 December 2009, 12:20:38 »
Look at the pic tunnie put in and the *bolt* is the one you can see the head of in the hole of the dipstick plastuic handle.
The thing is known as the bastard bolt for a reason too as yoiu will definitely find out.
GudLuk and order plenty of new skin and patience!
Re: V6 EGR
« Reply #9 on: 24 December 2009, 12:20:52 »
Undo the power steering reservoir bracket as well ;)
Re: V6 EGR
« Reply #10 on: 24 December 2009, 12:22:08 »
No its not, that one looks like the bracket for the aircon pipe
« Last Edit: 24 December 2009, 12:22:40 by Elite_Pete »
Re: V6 EGR
« Reply #11 on: 24 December 2009, 12:31:10 »
i still can't see of feel the damn bolt, bl00dy V6's. Its going to have to go back together shortly if i cannot find it.
Re: V6 EGR
« Reply #12 on: 24 December 2009, 12:35:07 »
Follow the dipstick tube down and about level with the power steering pipe and to the right iirc of the dipstick tube you should find the barsteward bolt.
Re: V6 EGR
« Reply #13 on: 24 December 2009, 12:47:18 »
still cannot see it, got enough trouble getting hand in there. This one is for a garage, its going back together.
Re: V6 EGR
« Reply #14 on: 24 December 2009, 13:56:11 »
Chicken ;D ;D ;D
