Author Topic: Headlamp Washer Jets  (Read 2328 times)
« on: 18 December 2009, 00:57:41 »
How are these powered... Relay?
Pump OK, Washer switch working fine but no power activating the pump.
Anyone able to help please?? Can't find relays mentioned in the handbook ::) ::)
Re: Headlamp Washer Jets
« Reply #1 on: 18 December 2009, 05:54:50 »
..... Can't find relays mentioned in the handbook ::) ::)
Towards the front of the triangular engine bay fuse/relay box (2nd back?), it's the one with a fuse right next to it. :y
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #2 on: 18 December 2009, 06:35:53 »
Suppose you have tested for power at the pump? Pump may be shot too.
GudLuk
« Reply #3 on: 18 December 2009, 07:23:58 »
GudLuk
Thanks though :y :y :y
« Reply #4 on: 18 December 2009, 07:25:16 »
Thanks Andy... I'll have a play at some point,,, Doubt it'll be today though, with a few inches of snow down ::) ::)
mantahatch
« Reply #5 on: 18 December 2009, 07:34:50 »
Don't no about Omega system as I don't have headlight washers, but on others I have seen they don't work unless the headlights are switched on.
« Reply #6 on: 18 December 2009, 16:33:48 »
Yep... They were working but have stopped... Pump OK but not powering when they're meant to so I reckon it'll be a relay ;) ;)
I_want_an_Omega
« Reply #7 on: 18 December 2009, 16:58:56 »
As you open the fuse box under the bonnet (the triangular one), its near the front and has a fuse holder next to it IIRC.
« Reply #8 on: 18 December 2009, 17:00:59 »
Have you been copying my answer???  ;D  ;D  ;D  ;)  ;) :y
I_want_an_Omega
« Reply #9 on: 18 December 2009, 17:13:54 »
ha ha, looks like it dosn't it? I must have been in a trance - we both gave similar answers though which was good.
I added headlight washers to my Mig and plugged into the empty relay socket. Worked first time :y
« Reply #10 on: 21 December 2009, 14:44:38 »
I've found the correct relay but there's no fuse in the holder.... What is the fuse for and what rating should it be please?
« Reply #11 on: 21 December 2009, 17:08:27 »
Am I being a bit vague here ???  But those two statements don't seem to tie up !!!!
 :o :o :o :o :o
« Reply #12 on: 21 December 2009, 21:32:24 »
 :o :o :o :o :o
They may well add up completely... I'm thinking I may have removed the fuse at some point (like when doing the LPG conversion) and that's why they're no longer working :-[ :-[ :-[
« Reply #13 on: 23 December 2009, 21:21:00 »
Anyone???? :-? :-? :-? :-?
« Reply #14 on: 23 December 2009, 21:27:27 »
Do the pictures here help at all ???
No fuse ratings but colours given ... so if you know your fuse rating/colour settings .......  :)  its item 12a and its green ... which I think is 20 amp for some reason !!
http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
apparently green is 30 amp ....
http://www.extremeautoaccessories.co.uk/products.php?section=4477
« Last Edit: 23 December 2009, 21:30:22 by entwood »
