Author Topic: gearbox help  (Read 983 times)
wideboy
  • ipswich
gearbox help
« on: 28 December 2009, 09:02:20 »
driving last night, gears started to slip   (auto box )engine reving, not getting any were, smoke pouring out from gearbox, bad smell ( like gas)
recovered by rac,  got no gears at all now, put it into drive, and it just revs, this sounds lots of pennys
help  :'( :'( :'( :'( :'(
Re: gearbox help
« Reply #1 on: 28 December 2009, 09:29:21 »
first off check the ATF level
RobseyMV6
  • west sussex
Re: gearbox help
« Reply #2 on: 28 December 2009, 09:35:27 »
Did you get a warning light come up on dash?
or now if you start car?
Re: gearbox help
« Reply #3 on: 28 December 2009, 09:38:56 »
Tunnie is probably right with the idea of low ATF, however, if the gearbox got hot enough for smoke to be pouring from it, I think I'd be looking for A N Other gearbox. An auto 'box rebuild can easily cost £1000.  :(
Re: gearbox help
« Reply #4 on: 28 December 2009, 09:40:29 »
If the gearbox is toast, be much cheaper to ditch the old one and bolt a new one in. AR25's are plentyful, and should be no more than £100 or so
Might be worth posting up your location  :y
« Last Edit: 28 December 2009, 09:40:48 by tunnie »
Re: gearbox help
« Reply #5 on: 28 December 2009, 09:43:06 »
Tunnie is probably right with the idea of low ATF, however, if the gearbox got hot enough for smoke to be pouring from it, I think I'd be looking for [size=12]A N Other[/size] gearbox. An auto 'box rebuild can easily cost £1000.  :(
Hence my comment re A N Other rather than a new or rebuilt auto 'box  :y
Re: gearbox help
« Reply #6 on: 28 December 2009, 09:57:52 »
Yup i am agreeing with you here  ;D
Re: gearbox help
« Reply #7 on: 28 December 2009, 10:00:17 »
 ;D ;D ;D ;D :y
