Author Topic: Water leak - where to check  (Read 1017 times)
Martin_1962
« on: 29 December 2009, 15:17:56 »
The car has developed a water leak.
All the below are recently changed this year
HBV
Head gaskets
Oil cooler
One LPG hose
Water pump
Coolant bridge washers and bolts
So where do I look next please?
One symptom, the windows seem to mist up easier than normal but carperts are dry
Markjay
  • London
Re: Water leak - where to check
« Reply #1 on: 29 December 2009, 15:19:19 »
Heater matrix? But you knew that....
Alas, no more Omegas....
« Reply #2 on: 29 December 2009, 15:20:05 »
you've changed the above, but they still could be leaking, have you checked all the usuals?
How much water are you loosing?
Martin_1962
« Reply #3 on: 29 December 2009, 15:21:21 »
About a litre over a couple of weeks
Will check the LPG tee pieces as well as I had one split 2 years ago
« Reply #4 on: 29 December 2009, 15:22:48 »
do the usual checks around the engine bay for any damp pipes/joins
Martin_1962
« Reply #5 on: 29 December 2009, 15:39:07 »
Bit wet & cold for that. (and now dark)
I wonder if JV6CDX wants a look while I repair his fob ;D ;D ;D ;D
« Reply #6 on: 29 December 2009, 19:49:30 »
Easy way out mate  :y
