Author Topic: manifold  (Read 1284 times)
cmacleod540
  • cheshire
manifold
« on: 31 December 2009, 17:50:01 »
any ideas  fault code p0420
took car to v/hall told req new cat plus new exhust manafold due to a hair line crack price inc lab££££
went to kwick fit they told me cat is fine iam going back on saturday for further look due to eml still on,could the crack on the manafold bring up this fault code.
happy new year you lot
Welung666
Re: manifold
« Reply #1 on: 31 December 2009, 18:27:43 »
Yes a cracked manifold could cause it, it'll be drawing air in the crack and affecting the o2 readings.
cmacleod540
  • cheshire
Re: manifold
« Reply #2 on: 31 December 2009, 18:32:31 »
i understand the manifold will req replacing would this be quite easy for me to do ie undo a couple of nuts and replace the seals,or is tere a lot more involved
Welung666
Re: manifold
« Reply #3 on: 31 December 2009, 18:37:35 »
Ideally you'll need to get 10 x studs, 10 x nuts from Vx to replace the ones currently fitted, a new genuine Vx multi-layer gasket and a replacement manifold (2nd hand OK). Couple of hours work to the less experienced :y
[edit]We are talking exhaust manifold here aren't we?[/edit]
« Last Edit: 31 December 2009, 18:38:48 by Welung666 »
Re: manifold
« Reply #4 on: 31 December 2009, 18:39:23 »
And hope that none of the originals snap when trying to extract them. :'(
cmacleod540
  • cheshire
Re: manifold
« Reply #5 on: 31 December 2009, 18:42:50 »
yep exhaust manifold  i will give it a go pop some wd40 pre job
 :) ;) :D ;D >:( :( :o 8-) :-? ::) :P :-[ :-X :-/ :-*
thanks again have a goooooooood one
« Last Edit: 31 December 2009, 18:43:55 by cmacleod540 »
Welung666
Re: manifold
« Reply #6 on: 31 December 2009, 18:44:16 »
Put that away and get yourself some proper penetrating fluid, PlusGas or the like :y
Re: manifold
« Reply #7 on: 31 December 2009, 18:44:47 »
Plusgas is an easing/releasing agent. WD40 is IMHO a waste of time :y
Sh$t, must type faster ;D ;D
« Last Edit: 31 December 2009, 18:45:26 by RobG »
cmacleod540
  • cheshire
Re: manifold
« Reply #8 on: 31 December 2009, 18:46:12 »
cheers guys ;D
