Author Topic: inside of car misting up  (Read 1624 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
« on: 30 December 2009, 18:26:02 »
Even with heaters on full, only warmish air coming through vents.Also console says check brake light but they are fine,any ideas much apreciated moggy :y
hotel21
  • The Kingdom of Fife
Re: inside of car misting up
« Reply #1 on: 30 December 2009, 18:57:45 »
Firstly, for the check light, does it extinguish after first application of the brake?  if so, then its only the inbuilt circuit checkinmg mechanism.  If not, then one of the lamps will be out, just a case of defining which.  System is a tad sensitive to bulb makes....  Gen VX is relatively cheap on Trade Club.
As to the heating/demisting then hold, I think, auto and off together for a few seconds until you hear all the servo's resetting.  May make a difference.   :y
« Last Edit: 30 December 2009, 18:58:45 by hotel21 »
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #2 on: 30 December 2009, 19:05:08 »
Check/replace pollen filter .... cured my steaming up issue , the filter was filthy  :-[
moggy
  • hartlepool
« Reply #3 on: 30 December 2009, 19:28:14 »
Hotel 21 First of all thanks for replying,brake light warning comes on when i first put on the ignition.It goes off when i press the brake pedel,but as i am driveing it comes back on.I have cheacked the lights they are ok,regarding the heating i dont understand what you mean by holding auto and off together bit of a thick brummy i am  :-[
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
« Reply #4 on: 30 December 2009, 19:59:28 »
Think he means push the 'off' & 'auto' buttons at the same time on the climate control panel untill you hear a noise. :)
Check the pollen filter aswell this will cause misting if dirty.
steve2.5cd
  • Blackburn, Lancs
« Reply #5 on: 30 December 2009, 22:25:08 »
Assuming you have climate control that is ? ;)
« Last Edit: 30 December 2009, 22:26:13 by steve18gls »
moggy
  • hartlepool
« Reply #6 on: 31 December 2009, 10:22:44 »
Hi guys dont have climate con,its a 95 omega.If you had this problem where would you start as in the current wether you need alround vision.I would like to get it sorted today if poss thanks for any help moggy :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 31 December 2009, 16:47:37 »
There is a vent inside the boot right bottom behind  the panel under the cd player or first aid box often covered with items from the boot may help to make sure it is free of obstruction
« Reply #8 on: 31 December 2009, 19:12:02 »
If your brake lights on ok and the warning is on the MID then probable you have a make of bulb fitted the system does not like (eg Halfords bulbs)  Use either genuine Vx ( a tad pricey) or I've found Ring bulbs work ok.
HTH
