Author Topic: Cam Sensor location  (Read 1474 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Cam Sensor location
« on: 31 December 2009, 21:18:14 »
Sorry to be a pain but where is a cam sensor located on my 2.2 CD. A wee picture would be a great help as am not very up to date on miggys
Welung666
Re: Cam Sensor location
« Reply #1 on: 31 December 2009, 21:22:37 »
Top of your engine, at the front edge of the ecotec strip. Lift it slightly at the back and slide it towards the windscreen then lift it off. The cam sensor is the plug right at the front of the engine under the strip.
To remove it, take the 2 x 10mm nuts off the cable tray at the front of the engine, then the 4 bolts holding the cambelt cover on and remove. Then just loosen the 1 torx bolt holding the cam sensor in place, gently pull the cable upwards and it'll slide out. Unplug the old one, plug the new one in and reverse the above :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #2 on: 31 December 2009, 21:33:03 »
Many Thanks
« Reply #3 on: 31 December 2009, 21:45:51 »
going from the bottom up, its the second circle...
Welung666
« Reply #4 on: 31 December 2009, 21:50:14 »
Thanks Tun, I couldn't find a pic hence 'war and peace' above :P
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #5 on: 31 December 2009, 21:52:07 »
yes many thanks. makes it easier when you know where it is. cheers
« Reply #6 on: 31 December 2009, 21:54:46 »
Nabbed from my 2.2 cam cover gasket guide  :)
