Author Topic: HG sympytoms?  (Read 2480 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
HG sympytoms?
« on: 31 December 2009, 13:38:54 »
Me again,
Right, after my coolant dump on a spirited drive I fixed the leak and it seems to be running ok, except when I blip the throttle after leaving it to idle for a little bit, then I get what I can only assume is a misfire  :'(
Has my HG gone?
RobseyMV6
  • west sussex
Re: HG sympytoms?
« Reply #1 on: 31 December 2009, 13:45:25 »
If you blip it from idle it does make like a hiccup should we say, don't normally just pick up straight away.
Mine don't anyway
Gaffers
Re: HG sympytoms?
« Reply #2 on: 31 December 2009, 13:50:19 »
more than usual, almost stalls and then picks up as normal.  Doesnt happen all the time.
RobseyMV6
  • west sussex
Re: HG sympytoms?
« Reply #3 on: 31 December 2009, 13:55:20 »
Takes alot for a HG to go i believe
Gaffers
Re: HG sympytoms?
« Reply #4 on: 31 December 2009, 13:57:01 »
I know, but I am wondering what could cause this hesitation....
Re: HG sympytoms?
« Reply #5 on: 31 December 2009, 14:12:27 »
Any codes?
RobseyMV6
  • west sussex
Re: HG sympytoms?
« Reply #6 on: 31 December 2009, 14:16:07 »
wouldn't the system blow up pressure and blow pipes off before fans cut?
« Last Edit: 31 December 2009, 14:16:34 by RobseyMV6 »
Gaffers
Re: HG sympytoms?
« Reply #7 on: 31 December 2009, 14:19:14 »
Any codes?
Good point, just checked. 19 .. and its recent.
Re: HG sympytoms?
« Reply #8 on: 31 December 2009, 14:21:54 »
Any codes?
Crank sensor it is, then....
Probably as a result of the cable being distrurbed, and already brittle, hence finishing it off, when the cooler job was done....
Gaffers
Re: HG sympytoms?
« Reply #9 on: 31 December 2009, 14:25:53 »
Any codes?
Wouldnt that stop me from starting the car though?  If thats all I am a very happy chappy.
Re: HG sympytoms?
« Reply #10 on: 31 December 2009, 14:33:41 »
Any codes?
It doesn't always just result in starting problems - sometimes stalling, cutting out, hesitation..... and general poor running, if the ECU doesn't know where the crank is at..  :y
Re: HG sympytoms?
« Reply #11 on: 31 December 2009, 14:35:53 »
Could get the garage to do a sniffer test when you take it for MOT. :y
RobseyMV6
  • west sussex
Re: HG sympytoms?
« Reply #12 on: 31 December 2009, 14:36:39 »
Club card vauxhall i was told only £47 not bad?
have a few spares ones here  ;D ;D
Omegadoha, Desert Member
  • Doha, Qatar
Re: HG sympytoms?
« Reply #13 on: 31 December 2009, 14:38:05 »
Any codes?
Whrn my crank sensor was defective, it would start up ok and then cut later.
Gaffers
Re: HG sympytoms?
« Reply #14 on: 31 December 2009, 14:40:17 »
Any codes?
Will this affect emissions at all?
The local stealers are proving useless yet again and now closed  >:(
