Author Topic: steaming from air con unit  (Read 1342 times)
4greening
« on: 30 December 2009, 20:01:54 »
2.2 dti steaming after 2minuites of starting steam from air con unit
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: steaming from air con unit
« Reply #1 on: 31 December 2009, 09:09:33 »
When you say air con unit, do you mean under the bonnet, or inside the car?
I like red cars
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #2 on: 31 December 2009, 10:49:18 »
Who would want to use the AirCon at this time of year? Brrrrrrrrrrrrrrrrrrr.
If it is inside it may just be condesation being dried off the heat exchanger matrix.
GudLuk
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #3 on: 31 December 2009, 13:24:04 »
GudLuk
Air conditioning isn't just for keeping the car cold, I use mine all the time, saves having condenser problems.
I like red cars
Welung666
« Reply #4 on: 31 December 2009, 13:27:41 »
GudLuk
Me too, clears a misted up windscreen in half the time :y
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #5 on: 31 December 2009, 13:29:32 »
GudLuk
We're going off topic, still need to find out where the steam is coming from.
I like red cars
Bionic
  • Leicester
« Reply #6 on: 31 December 2009, 16:44:11 »
The comment about the AirCon being used in this weather was a joke! Mine is on permanently too and I make full use of the Climate Control. All you can do is to get the inside of the car totally dried out, I use an electric fan heater for a few hours with the windows cracked open, and run the AirCon until it has had the time to dry off the heat exchanger matrix. That is not the condenser next to the coolant rad! Mine was like it for a good while after the heavy rains last year but did eventually clear. If you are not losing coolant then that is probably the problem.
« Last Edit: 31 December 2009, 16:44:39 by its.ray »
arlee219
  • Birmingham
« Reply #7 on: 01 January 2010, 14:21:49 »
"heat exchanger matrix"
where is that stuff located please?
I'm driving 2.2 CD Auto Xreg.
Have similar probs with AC (headgaske changed and since then AC's blowing only cold air :(((   )
2.2 CD Auto LPG Conv Xreg
« Reply #8 on: 01 January 2010, 14:42:46 »
That is not the condenser next to the coolant rad!  .....
It is!
clicky The 'heat exchanger' you're refering to inside the cabin is the evaparator.  :y  :y  :y
« Reply #9 on: 01 January 2010, 15:47:07 »
It is!
Yup, the condensor & dryer are hidden on V6, but you can see them on 4 pots, its inbetween the main cooling rad and cooling fans.
