Author Topic: auto gearbox 2.6 v6  (Read 1325 times)
kentguy
  • kent
  • hi
auto gearbox 2.6 v6
« on: 01 January 2010, 20:35:14 »
hi auto box goes into safe mod stop turn engine off restart no probs at times will go into safe mod when engine not running any ideas ty
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: auto gearbox 2.6 v6
« Reply #1 on: 02 January 2010, 04:09:47 »
would check the wiring from auto box to its ecu, if ok would put it on a tec2 to get the fault codes.
« Reply #2 on: 02 January 2010, 05:19:16 »
might suspect selecter switch, remove clean inspect for ware and set up correctly on refitting. When was atf last changed? But as rusty says may well need tech2 to diagnose, see The Boys teach2 site at the bottom of any of his posts for details.
wideboy
  • ipswich
« Reply #3 on: 02 January 2010, 07:16:13 »
check ATF level first,
phill
