Author Topic: Just a few issues!  (Read 2989 times)
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
Just a few issues!
« on: 28 December 2009, 18:05:12 »
Car is lovely to drive, just getting annoyed with following problems;
Gear box (auto) regularly comes out of gear and you have to either drop into 3rd or wait for the revs to drop down and automatically crashes back usually sending it into limp home mode. I suspect not an easy fix?
Had both rocker cover gaskets changed twice and still oil is leaking, have been told need to replace with new rocker covers with seals built in? sounds expensive.
Oil leaking causes emmissions light to permanently be on, if car is parked facing up a hill the enging missfires (probably the oil?) on start and emmisssions light flashes then stays on.
Christmas eve after getting petrol I returned to car opened an unlocked un alarmed car(as wife was still inside) and a different to usual car alarm immediately went off it was not the horn, it only stopped when I started the car and drove away!
Last night this alarm and the main alarm both went off a number of times making me very unpopular, after reading a few posts on here I suspect the secondary alarm noise is the power sounder?
I spent morning cleaning all door catches and checking bonnet sensor wiggled a few fuses! and have not had an alarm since.
Any advice help on any of these things might help me not want to get rid of the car! I have lived with the autobox problem 3 years but the wife hates it when it happens
thanks
Pete
www.impactcls.co.uk - Flight Case Manufacture
Re: Just a few issues!
« Reply #1 on: 28 December 2009, 18:09:19 »
Do the pedal trick for the codes http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Never heard of cam covers with built-in seals/gaskets.
Were genuine gaskets used initially. Camcover bolts torqued to 8nm.
Welung666
« Reply #2 on: 28 December 2009, 18:14:53 »
If you're on the 3rd set of cam covers and they are still leaking then either a) the breathers weren't cleaned or b) they've been over tightened.
Gearbox needs an oil and filter change after a proper techII code read and software update.
« Last Edit: 28 December 2009, 18:15:36 by Welung666 »
sexydaz
« Reply #3 on: 28 December 2009, 18:16:29 »
thanks
Pete
bloody hell that would of annoyed me,have you checked anything on it like atf level and so on theres loads of posts on ere about autobox probs and your rocker seals the cam covers need genyouwine seals not chepo ones,other probs anyone :question
Matchless
  • Nottingham
    • A white van
« Reply #4 on: 28 December 2009, 18:18:22 »
If you're on the 3rd set of cam covers and they are still leaking then either a) the breathers weren't cleaned or b) they've been over tightened, or c) non-genuine Vx seals were used. Pattern ones last a few weeks if you are lucky.
Welung666
« Reply #5 on: 28 December 2009, 18:19:44 »
That too ML ;D ;D
Matchless
  • Nottingham
    • A white van
« Reply #6 on: 28 December 2009, 18:20:42 »
You are not far from Nottingham and Marks DTM..he can check the 'box for error codes and might help to change the box fluid and filter if you ask nicely.
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #7 on: 29 December 2009, 00:30:06 »
gearbox problem could be the 2/3 soleinoid . Richard from this forum had the same problem and a new one seemed to fix it hope this helps :y
v6 cam locking kit  member:y
Impact Pete
  • Derby
« Reply #8 on: 29 December 2009, 18:20:36 »
Thanks for the links, the codes were 1700, 0173, 0170, 0300, 0304
Not sure if seals were genuine suspect not! paid enough.
Impact Pete
  • Derby
« Reply #9 on: 29 December 2009, 18:22:44 »
Gearbox needs an oil and filter change after a proper techII code read and software update.[/quote]
All been done, it seems to be an electrical issue so maybe as sparkyw666 suggests it may be solenoid?
Impact Pete
  • Derby
« Reply #10 on: 29 December 2009, 18:24:09 »
Will look into that any advice on it would be great
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #11 on: 29 December 2009, 18:41:42 »
does this usually happen at around 30 mph from 2nd to 3rd ? Does the revs go up then bang mines is doing the same and richard said a new soleinoid cured his :y
« Last Edit: 29 December 2009, 18:44:24 by sparkyw666 »
Impact Pete
  • Derby
« Reply #12 on: 29 December 2009, 22:19:54 »
Hi thats exactly the problem, where is it located?
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #13 on: 29 December 2009, 22:53:29 »
the soleinoid it located in the autobox you need to take the sump off to get to it . Soleinoid is about £80 from vx not cheap. If u pm( richard A) he could tell u far more than i know about it hope this helps  :-):-) :y
Impact Pete
  • Derby
« Reply #14 on: 31 December 2009, 16:46:06 »
regarding the alarm, after reading all the posts about removing power sounder, I did but 5mins after locking  car, the alarm is still going off. Really starting to be annoying, tried locking on key only still goes off, can't really leave it unlocked where I live!
