Author Topic: Who Wants to Do My Rocker Gaskets?  (Read 1162 times)
Humpy
  • Tunbridge Wells, Kent
« on: 02 January 2010, 21:35:44 »
Well, not mine but my mates 2.5CDX '98 Estate? Either in the SE (I'm in Tunbridge Wells, he's in Fokestone) or we could bring the car to you if you're not a million miles away. Roughly how much would it be do you reckon? Thanks.
Humpy
Re: Who Wants to Do My Rocker Gaskets?
« Reply #1 on: 02 January 2010, 21:38:25 »
i'd easily volunteer for a 4 pot cam cover, but not V6, noooo way  ;D
« Reply #2 on: 02 January 2010, 22:36:52 »
Too far for me but £130 supplied, fitted and breathers cleaned ;)
lozzy
  • Irmscher UK Sales and Support
« Reply #3 on: 03 January 2010, 01:28:37 »
Its not a too bad job im not mechanicly minded but with a simple tool kit i done mine :D
1 Omega Estate 100 speakers :D
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #4 on: 03 January 2010, 05:33:51 »
If I were you m8 I would set to and do the job myself. It is a straight forward one and only requires a basic set of kit. Just make certain that you only use the GENUINE VX joints! They are the only ones that will guarantee no oil leaks. The aftermarket ones will not fit correctly and WILL leak so you will have wasted your time and money because you WILL have to redo them. If you run a Mig you should have the basic kit anyway. Many jobs are described as difficult but in reality are pretty straight forward if you follow the excellent guides in this forum. If you get stuck just post a PM on the relevent section, they are very quick to answer. A torque wrench is also a must because incorrect tightening will cause either leaks or damage by stripping threads in the alloy components. For many jobs i use a 3/8 drive which is up to 12.00 quids from ebay and does most of the smaller jobs. I have used many of the guides and saved a hell of a lot of money. I actually enjoyed it knowing it was a job well done too!
Go on - a bit of muck under the fingernails is not that bad................think of the job well done satisfaction and being able to tell everyone you did it yourself! You can congratulate yourself afterwards with a well deserved pint or two, not while driving though!
GudLuk
