Author Topic: My Omega Misfire chapter 2  (Read 2564 times)
lozzy
  • Irmscher UK Sales and Support
« on: 27 December 2009, 16:10:03 »
right new gaskets on and all put back together but errm ive acquired a pipe lol
its still misfiring up to 1500rpm and still stinking off eggs  :'(
wheres this one go?
1 Omega Estate 100 speakers :D
  • Auckland
    • Mazda MPV
Re: My Omega Misfire chapter 2
« Reply #1 on: 27 December 2009, 16:17:00 »
It looks like the one that goes to the fuel pressure regulator. Does the other end go to a spigot next to the throttle body?
lozzy
« Reply #2 on: 27 December 2009, 16:21:16 »
its connected to this pipe on green corcle
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 27 December 2009, 19:40:25 »
Should be fitted to the fuel pressure regulator, 30 mm dia shiney metal thing under the plennum.
lozzy
« Reply #4 on: 29 December 2009, 08:51:22 »
well found the pipe re fitted it changed the plugs they were shafted allburnt and rusty from where they was swimming it idled much better but still missing and sounding like a subaru and the engine is hunting  so it looks like im going to have to change the cats  :-/
« Last Edit: 29 December 2009, 08:53:48 by lozzy »
« Reply #5 on: 29 December 2009, 10:14:52 »
Don't condemn the cats yet mate
Are you SURE you have a spark on each plug - and no air leaks? Any fault codes?
lozzy
« Reply #6 on: 29 December 2009, 10:28:58 »
yea i deffiantly sure i have spark on each one because idle over 1500revs the misfire is not there and when driving under laod it feels very restrictive when i booted it in second gear the enfine sounded very strained and topped out at about 40mph  :-? there is no EML light comming up
« Last Edit: 29 December 2009, 10:31:19 by lozzy »
« Reply #7 on: 29 December 2009, 10:31:03 »
As James says. Have you checked for any fault codes?
  • Auckland
    • Mazda MPV
« Reply #8 on: 29 December 2009, 10:37:23 »
The cats stink of rotten eggs because they are being flooded with unburnt fuel. Fix the misfire first & then see if the cats have suffered.
As others have said, check for fault codes first. There are lots of possible causes for a misfire (but damaged cats isn't one I am aware of)
lozzy
« Reply #9 on: 29 December 2009, 10:41:47 »
i suppose that if it was the cat it would chuck up the eml light as the last lambada sensor would get a bad value ?
so looks like  next up is the dis pack to be changed
« Reply #10 on: 29 December 2009, 11:24:03 »
Not necessarily. Have you checked for codes?
lozzy
« Reply #11 on: 29 December 2009, 11:35:40 »
no i havnt would the paperclip test show any codes even if the engine managment light has not been on ?
lozzy
« Reply #12 on: 03 January 2010, 13:19:45 »
well all sorted got some Leads and its now running like a dream :D so i have changed rockers gaskets plugs and leads leads
moral of the story if you rocker is leaking get it sorted straight away it will save you money  ;D
