Author Topic: Noisy heater fan bearing  (Read 914 times)
smokingomega
  • Leeds
« on: 02 January 2010, 11:16:24 »
Hi
I was wondering if there is any easy way of getting to my heater blower moter?
the problem is i think the bearings need a bit of a lube.
I`ve heared that they are a bit of a pig to get to
Cheers
Re: Noisy heater fan bearing
« Reply #1 on: 02 January 2010, 11:24:06 »
Remove glovebox. Have a read of this.http://www.omegaowners.com/forum/YaBB.pl?num=1261507084
« Reply #2 on: 02 January 2010, 13:18:54 »
Removing blower motor is a pain in the rse - top two bolts have to be removed (& refitted) by feel!  You need to drop glovebox out, remove trunking tray, undo fixing bolts disconnect electrics and then waggle the b*gger out! As Hayes says "refitting is the reverse of removal"  ;D
Took me a couple of hours to swap blower motors on the Estate whilst standing on my head under the dash!!
smokingomega
  • Leeds
« Reply #3 on: 02 January 2010, 18:05:04 »
I`m not actually wanting it out all I need to do is just lube the bearings. it has that dry metalic sound now an then an i think a squirt of oil should sort it out.
Thanks for the help
« Reply #4 on: 03 January 2010, 16:00:13 »
The Estate blower had noisy bearings - swapped it for another blower courtesy of an OOF breaker.  Cannot see a way to lube bearings on this!! Think you will end up taking it out mate  :(
Page created in 0.027 seconds with 16 queries.
