Author Topic: heater problems !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  (Read 2323 times)
medwaykent
« on: 29 December 2009, 13:30:58 »
well i back on with same probs as a while back no heat from heater i flushed matrix through last time and got bit of warmth for day or so  :)then back to no heat again so been out there again today and flushed through again reconnected resyncened  heater by pushing auto button and off button at same time and still cold :'( could it be the HBV have taken vacumm pipe off top off hbv there doesnt appear to be any sucking or blowing coming from end off it .. should there ? forgot to mention its an omega 3.0 elite finally should the digital heater numbers be visable in the dark ? bulbs gone ?
medwaykent
Re: heater problems !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #1 on: 29 December 2009, 13:50:25 »
forgot to mention top hose going into matrix very hot bottom hose coming out very cold !!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #2 on: 29 December 2009, 14:13:09 »
still sounds like you have a blockage or airleak in the matrix, squeeze the hot pipe several times, if this has no affect, take both pipes off and flush well again with hose.
Also, is you 1 key stuck??  :-/
amba
  • Medway towns
    • German V6
« Reply #3 on: 29 December 2009, 14:24:45 »
Sounds like the matrix has a good blockage off crud.
Connect a piece of hose to each heater pipe to make access easier and then with a funnel on 1 piece slowly poor in someC/H sludge remover available from B@Q. Leave that to work for a while and then flush that lot out,then repeat on the other pipe and again leave for a while then flush through with as much pressure from hose as possible.
May need to repeat several times but with flushing both ways and some chemical you should get it to improve,but do remember that the copper pipes in the matrix are very narrow and it will not require much crud to cause a blockage and the way the pipes are layed out it will appear that it is clear and free running even when some bits are still blocked up.
« Reply #4 on: 29 December 2009, 14:37:45 »
::) ::) ::) ;D ;D
medwaykent
« Reply #5 on: 29 December 2009, 16:49:25 »
when i flushed through this afternoon water was going in one pipe and out  the other and vica versa does that not mean its clear ?  :-?
amba
  • Medway towns
    • German V6
« Reply #6 on: 29 December 2009, 16:56:55 »
The way the pipes are layed out in the matrix means you could have non,or very little actually through the main heater section but it will flow in and out without restriction so it is worth trying some chemical to try and clear the pipes.
Imagine a central heating radiator where water goes in 1 side...runs through the bottom without enetring the heater vanes and then coming out the other end.It appears clear but due to the volume of hot water within the system you get no heat...same principal. Somewhere on the forum is a picture of the heater matrix cut open and it then becomes clear why and how they get blocked up.
Try some Fernox or B@Q radiator sludge treatment..my money is on that to clear it and then you will have plenty of nice cabin heat.
medwaykent
« Reply #7 on: 29 December 2009, 17:14:24 »
thx amba will try in the morning ....
 ;D
medwaykent
« Reply #8 on: 30 December 2009, 19:57:21 »
well i put some central heating cleaner in a couple of times this morning and left it for about an hour each time washed it through and yipeeee some heat not boiling but miles better than it was .. will do it again tomorrow thx guys :-*
BigJohn309
  • grantham , lincolnshire
  • new omega owner
« Reply #9 on: 01 January 2010, 21:54:52 »
this is very helpfull as im having much the same problem .
Boatboy
  • St Albans
« Reply #10 on: 03 January 2010, 11:52:57 »
Have you got the small auxilliary pump below the air filter?
If that is not working or is blocked it can create a degree of restriction in the heater circuit, possibly contributing to the blocking of the matrix in the process. When working you can feel it vibrate.
Opinion is divided as to whether it serves much useful purpose, but if its not working a quick fix to reduce its resistance is to undo the four screws and drop (literally) the impeller out.
Steve
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #11 on: 03 January 2010, 13:09:07 »
Out of interest, which models had that aux pump fitted??
Omega 2.6 V6 Elite in Shiny Black
medwaykent
« Reply #12 on: 03 January 2010, 21:43:14 »
well went and bought more central heating cleaner and stuck into matrix for couple hours  washed it through a few times conected up again a wow warmer than before .. will try again at weekend as still think it should be warmer..  ;D ;D ;D ;D ;D ;D
