Author Topic: 2.5 t/c lockup  (Read 1124 times)
mark3
  • Rainahm Village~Essex
2.5 t/c lockup
« on: 03 July 2009, 18:31:50 »
Hi all, i have a 97 2.5 V6 auto estate that has never seem to have had torque converter lock up! when cruising at speed and the throttle pressed the revs increase momenterily then return to where they where before increasing with road speed!
is this a common fault and if so anyone know if theres an obvious repair???
Ian_D
  • York
Re: 2.5 t/c lockup
« Reply #1 on: 04 July 2009, 18:00:00 »
The T/C Lock should kick in at 50mph, providing your using lightish throttle, and not going up a steep hill!
Also, it wont lock if its in '1', '2', or '3' or Sports Mode
I would check oil level in the box first and take it from there.
[size=12]
mark3
Re: 2.5 t/c lockup
« Reply #2 on: 06 July 2009, 21:47:40 »
Thanx for the reply, the fluid level is ok and i sort of guessed the rest. is there a relay for this, or an auto ecu i can look into? i have very little info on Omega auto trans operations!!
unlucky alf
  • worksop, notts
Re: 2.5 t/c lockup
« Reply #3 on: 06 July 2009, 22:13:44 »
there is an auto box ecu which is mounted on the kick panel in the drivers footwell quite high up, ive heard of updates being done on these but not sure how its done :-/
Re: 2.5 t/c lockup
« Reply #4 on: 03 January 2010, 23:47:27 »
Sounds like normal behaviour to me. It goes out of lockup momentarily with a quick change in throttle. If you gently squeeze the throttle at cruising speed > 50 MPH, does the RPM immediately increase or follow road speed?
Lockup is not a separate function with an electronic gearbox. It's controlled by the ECU along with the rest of the gearbox. If you still suspect a problem and fluid level is OK the next step would be to get it on a Tech 2 and look for trouble codes in the gearbox ECU IMHO.
Re: 2.5 t/c lockup
« Reply #5 on: 04 January 2010, 09:23:57 »
*cough cough*, having a tidy up and disturbing the dust Kev?
;D
Re: 2.5 t/c lockup
« Reply #6 on: 04 January 2010, 10:21:42 »
Hmm. Not sure what happened there. :-[
