Author Topic: Door handle whoops  (Read 1592 times)
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
Door handle whoops
« on: 04 January 2010, 10:33:52 »
So the CID says it's -7C outside, after I manage to get into the car via the passenger door.  I can't get in via the driver's door as it didn't unlock, but a quick lock/unlock sorts that.
Climb in from passenger side as driver's door still doesn't open.  Try to push open from the inside but only succeed in snapping what I assume is the cable that opens the door, as I end up yanking the handle rather hard ;D.
So, I guess this means the door card needs to come off etc. so is this a big job?  At least it's not the motor that unlocks the door, as that failed twice on my previous Omega...
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
Mr Hagon
  • South West London
Re: Door handle whoops
« Reply #2 on: 04 January 2010, 10:49:28 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152953579 :y
Ta, getting lazy again, should have checked to see if there was a guide to removing the card.  Just need to find out what I've broken now...
« Reply #3 on: 04 January 2010, 10:59:24 »
It's a solid rod that links the interior handle to the lock mechanism. I would think if you've been heavy handed  ::) then it'll be the back of handle that's broke .......
Welung666
« Reply #4 on: 04 January 2010, 11:41:33 »
I've got a facelift door here if you need the handle or bar :y
  • Auckland
    • Mazda MPV
« Reply #5 on: 04 January 2010, 11:49:23 »
Can you open the door from the outside?
The interior handle might feel 'dead' because you have already unlatched the door but the mechanism might still be frozen (or the door seal still frozen).
Definitely time to wax the door seals and lubricate all of the locking mechanisms. (once you can get it open and get the door cards off).
Mr Hagon
  • South West London
« Reply #6 on: 04 January 2010, 12:08:37 »
A
I can open the door from the outside, fortunately.
Will see what happens when I go home tonight.  Sounds quite plausible in that the door is unlatched, but I expect the use of brute force and ignorance has broken something  ;D.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #7 on: 04 January 2010, 12:29:58 »
may just of snaped the plastic retainer.
Mr Hagon
  • South West London
« Reply #8 on: 04 January 2010, 13:17:48 »
A
Doh!  Just tried it now and it's broken.  Can get into the car but can't get out, so rather than climb over from the passenger side I shall be winding down the window and opening it from the outside  ;D.
Should it get warm enough by the weekend, and SWMBO lets me, I will endeavour to take the door card off and see what I've broken...
Page created in 0.021 seconds with 16 queries.
