Author Topic: might have blown heat gasket  (Read 866 times)
simon lee
« on: 04 January 2010, 22:42:43 »
the head gasket might have gone on my 2.6 v6 y reg i have read that the syptom may not meen its gone might be somthing els if any one can help that would be great.
Re: might have blown heat gasket
« Reply #1 on: 04 January 2010, 22:44:27 »
What symptoms are you seeing?
Head gasket failure is rare on the V6s, and traditional HG symptoms can be caused by more trivial problems. :y
simon lee
« Reply #2 on: 04 January 2010, 22:51:05 »
hi thanks for replying. well the car was my dads and he tells me that has always used a bit of oil and water but when i last went to top up the oil there was a white thick cream coloured stuf in the cap and round the inside of the filler nozel no over heating but white smoke out of the exgust
« Reply #3 on: 04 January 2010, 23:01:52 »
White "smoke" is common given the present temperatures ... just look at all the cars around you !!  its actually water vapour in the exhaust condensing as it hits cold air.
"mayonnaise" in the filler cap is common as that part of the filler remains cold and is prone to collecting condensation, especially if you only do short trips.
« Last Edit: 04 January 2010, 23:03:24 by entwood »
simon lee
« Reply #4 on: 04 January 2010, 23:16:10 »
thank i only tend to do 7 miles per trip and the white smoke just seem more. and the oil on the end of the dipstick is normal so you think there is nothing to worry about.
« Reply #5 on: 04 January 2010, 23:19:16 »
No major cause for concern. Doing short trips I`d recommend oil & filter changes every 3-5K and frequent motorway blasts
simon lee
« Reply #6 on: 04 January 2010, 23:26:51 »
thank god for that not a job i wanted to do thanks to every one for your help
simon lee
« Reply #7 on: 04 January 2010, 23:31:42 »
I do have some other small problems the air con dosn't work and the drivers do dosn't lock by remote but will go in to more deepth later going to bed now thanks again
