Author Topic: Getting very poor mileage with 2.5 automatic  (Read 2260 times)
Omegab25v6
« on: 03 January 2010, 12:50:42 »
Car is 1995 Omega B 2.5 automatic.
Sedan.
Yesterday i tested,about 9 at evening in city. So only few cars,not hevy traffic. I got about 15mpg, its about 16 L per 100km. Mostly easy ride,some harder moves with gas pedal.
I think its a lot.  Or not?
Whats the most typical problem? Is engine worn out or just screaming for big service(filters and those things).
Car odometer shows 230 000,but it is suspicious,because steering wheel is pretty worn.
Any information?
Edit:My English isnt very good  :)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Getting very poor mileage with 2.5 automatic
« Reply #1 on: 03 January 2010, 13:11:54 »
Your English is fine mate :y
Is the car missing? smelling of oil?
How often do you change the oil? Have the breathers been cleaned out? you would be suprised on how much difference that makes :y
Daz
« Reply #2 on: 03 January 2010, 13:15:39 »
your english is excellent, much better that some of the native speakers  ;D
15mpg is quite bad, as above check the breather system, but for it to be that bad something else has to be up.
Worth doing the 'paperclip' test to get some fault codes, instructions on this are in the maintenance guide second  :y
« Last Edit: 03 January 2010, 13:15:58 by tunnie »
  • Auckland
    • Mazda MPV
« Reply #3 on: 03 January 2010, 13:28:23 »
I found that a faulty thermostat wasn't allowing my engine to warm up properly which made fuel consumption worse.
What country are you in? Is your MID (computer) displaying miles per Imperial (English) Gallon?
US gallons are smaller. I don't know whether regionalisation would allow the MID to display US mpg or L/100kM. :-/
« Reply #4 on: 03 January 2010, 13:39:36 »
My guess is Europe hence the litres/100km. Americans doen't usually do metric  ;) ;) ;)
Omegab25v6
« Reply #5 on: 03 January 2010, 13:47:59 »
Dont smell oil,but i think is missing(Must check later) I have owned it about week or two. So dont know excactly yet. I havent changed oil ,but oil seems good brown,not black. Its also in to do list.
I havent cleaned breathers,but want to do this soon. Need to find garage first.
I did paperclip test. Only 12 (start of diagnosis) and 31 with engine not running. So its normal. And if running,only 12.
Engine is working 90-95 celsius. So its also normal i think. Coolant is clean and green. Oil cap has a little cream. But as i have heard its normal on a v6, if driven short distances.
Location is Estonia. We have -10 C at moment here :) And about 60cm of snow. It should be a record of long times.
Computer shows only date,time and outside temperature.
Yes,i know that US and Englist gallons are different, i calculated L/100km to English gallons :)
Also if car is stayed out all night,then it starts about 3-4 times. With every start it runs longer and dies. Finally starts beautifuly.
Ok,then its fine, i rembember english.  Mostly only reading,not writing,so words get forgotten
« Last Edit: 03 January 2010, 13:55:10 by rosco2 »
  • Auckland
    • Mazda MPV
« Reply #6 on: 03 January 2010, 13:48:07 »
Oops. L/100km plain as day in OP but I missed it  ::)
I was thinking there might be some confusion over units but 16 L/100km is very close to 16 Imperial mpg so that isn't the problem....
alunonhisown
« Reply #7 on: 03 January 2010, 13:57:07 »
Daz does MOBILE Tuning, sounds like a job for him, IMO.
Off you go Daz
Just the start you need to freshen you up
« Reply #8 on: 03 January 2010, 13:59:03 »
Not only will you learn more about how to mend/fix your car, you will also improve your English. Cem, in Turkey, has learned lots of swear words too!  :-[  :-[  ;D  ;D ;)
  • Auckland
    • Mazda MPV
« Reply #9 on: 03 January 2010, 14:01:20 »
I think that is correct for the 2.5  :y
That doesn't sound right. We occasionally get -8 Celsius on one or two nights a year (not for weeks at a time as central Europe does) but I would still expect the Omega to start first time.
Perhaps one of the temperature sensors (air intake or engine coolant) is giving a wrong reading to the ECU to cause starting difficulty and poor mpg?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #10 on: 03 January 2010, 14:07:43 »
Off you go Daz
Its a long bloody walk  ;D ;D
Omegab25v6
« Reply #11 on: 03 January 2010, 14:09:53 »
Air intake sensor is thinkable. Coolant sensor then should also give false readings to dash also? But its ok.
alunonhisown
« Reply #12 on: 03 January 2010, 14:10:56 »
PMSL
Freshen you up for the Rest Of Your Life, and you get to go in the Guinness Book for Most Dedicated Omega Mechanic
What, I just created a new New Years Honour
How Cool Is That?
« Reply #13 on: 03 January 2010, 14:11:15 »
Off you go Daz
Think even Estonia is out of reach for the dark one
  • Auckland
    • Mazda MPV
« Reply #14 on: 03 January 2010, 14:13:07 »
There are two coolant temperature sensors, one for the display and one for the ECU.
I know that Volkswagen coolant temperature sensors are very unreliable but I have never heard of one failing on an Omega.
« Last Edit: 03 January 2010, 14:14:19 by andyh »
