Author Topic: Exhaust emission  (Read 1131 times)
Omega M3
    • Omega 03 3.2
Exhaust emission
« on: 08 January 2010, 20:54:44 »
Hii all
While the engine running Exhaust emission light is on
What to do or check?
Re: Exhaust emission
« Reply #1 on: 08 January 2010, 21:24:01 »
common fault on 3.2's, something to do with the pre-cats i believe. Someone in the know will be along shortly  :y
« Reply #2 on: 08 January 2010, 21:26:24 »
Hii all
This is probably your answer http://www.omegaowners.com/forum/YaBB.pl?num=1253462747
Welung666
« Reply #3 on: 08 January 2010, 21:30:40 »
Use the link below and do the pedal trick on your car, I'd guess at 0420 and 0430, cat efficiency. If you do then the link Rob has posted is by far the easiest and cheapest way to beat it. If you're close by I'll do them for you like I did MarkMV6's
Omega M3
    • Omega 03 3.2
« Reply #4 on: 09 January 2010, 21:49:45 »
For sorry i'm in Kingdom Saudia Arabia
Can petrol octane affect on ?
« Last Edit: 09 January 2010, 21:50:46 by omegaM3 »
« Reply #5 on: 09 January 2010, 22:04:26 »
IMHO yes ... I seem to get the 0420/0430 problem twice a year ... within a couple of days of getting to France on holiday .. and then again a couple of days after I get back.
I know I run on LPG but I'm convinced that it is something to do with fuel quality/additive mixes.. the system just doesn't seem to like the change in fuel.
I use the maxscan to remove the codes and put the light out .. and just wait until the next time ..  :)
