Author Topic: New pollen filter  (Read 2730 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
New pollen filter
« on: 11 January 2010, 10:23:30 »
Picking up a new one just to check and make sure , old one feel,s fine and dry but is fuffy on one side ....would that mean it had it. Found about a cup full of water in the scuttel drain which was cleaned and has been good since. Also on my old one there is a arrow for air flow.
Should the arrow point to the inside of the car or the outside.
Thanks all
Steve.
joshwyatt
  • Oxford
Re: New pollen filter
« Reply #1 on: 11 January 2010, 10:30:03 »
Arrow should point towards the inside of the car. I had the same with mine, was a bit fluffy so just stuck a new one in. It made a big difference, for the sake of £14 or whatever it is I do it on all Omega's I've got.
Richard A
  • Aldridge, West Midlands
« Reply #2 on: 11 January 2010, 10:30:59 »
I think your 3.2 should have a 'carbon filter', in any event the 'air flow' is into the car.
regards
richard a
richard a
SP_3.2
  • Leicester
« Reply #3 on: 11 January 2010, 10:34:43 »
Good point  :y Getting a bit of misting on side windows which is a pain this time of year. Think the old one got a bit damp with even only a tad bit of water in it.
Off to the seller at lunch then ::)
SP_3.2
  • Leicester
« Reply #4 on: 11 January 2010, 10:38:17 »
regards
richard a
Very true ..Hope you are good Richard :y not had much chance to make the meets  :-[ hope to have some more time in the summer ;). I keep seeing a car just like yours around Liecester when on my bike..A11 i think not sure if it,s you.
Take care
Steve :y
Neil_MV6
  • Sutton Coldfield-West Midlands
« Reply #5 on: 11 January 2010, 11:19:49 »
How do you access the pollen filter in a facelift?
I haven't actually looked at mine all the time I've owned the car, gulp.  :-[
« Reply #6 on: 11 January 2010, 11:30:36 »
They're all the same!  :y  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
Neil_MV6
« Reply #7 on: 11 January 2010, 11:55:41 »
Thanks Andy.  :y
portomega
  • Port Talbot, S. Wales
« Reply #8 on: 11 January 2010, 13:46:32 »
Do you actually NEED a pollen filter? because i removed mine about 2 years ago and never got round to fitting a new one  ::) :-[
« Reply #9 on: 11 January 2010, 14:05:14 »
Facelifts will start turning on recirc all the time, due to air quality sensor (which is why facelift needs carbon filter)
