Author Topic: airbag light reset ?  (Read 1504 times)
gav mv6
  • leicestershire
    • m/f irmscher mv6 lpg
« on: 11 January 2010, 18:18:26 »
after the great drivers door opening at random when ever the car feels like it managed to sort that with a new lock from vaux great .....
but to access the bloody thing i could not for the life of me disconnect the motor conector at teh bottom , resorted to removing the black metal plate and disconect the blue plug , replaced everything now  re riveted it back on reconnect bat and light still on ...
can it be restet at home or do i have to visit the dealers ? thanx
Dam its hard work getting to 250 posts .......
bluepoint
  • Warrington
Re: airbag light reset ?
« Reply #1 on: 11 January 2010, 18:20:28 »
Tech two for a reset, unfortunately :(
However if you let your fingers do the walking I have used mobile services that do the same thing.
« Last Edit: 11 January 2010, 18:22:05 by bluepoint »
« Reply #2 on: 11 January 2010, 18:29:08 »
A 'Cheapo Tech II' will reset it too.  :y  :y
gav mv6
  • leicestershire
« Reply #3 on: 11 January 2010, 18:33:53 »
thank you !! , stupid question but i guess its a beay job for the tech 2 ??? or can someone help me ?
« Last Edit: 11 January 2010, 18:42:29 by xwai »
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #4 on: 11 January 2010, 18:34:19 »
were are you as some one near you may be able to sort it out.
« Reply #5 on: 11 January 2010, 18:39:59 »
tahnk you !! , stupid question but i guess its a beay job for the tech 2 ??? or can someone help me ?
eBay will buy you a 'Cheapo Tech II' for about £25/£30 however a real Tech II will set you back £3000  :o if you're lucky enough to find one!   :y
gav mv6
  • leicestershire
« Reply #6 on: 11 January 2010, 18:43:21 »
live in leicester but work in corby
« Reply #7 on: 11 January 2010, 19:06:27 »
Try Marks DTM - he's in south Nottingham. He has the real Tech2, and (more importantly) knows how to use it!
