Author Topic: HBV  (Read 3285 times)
HBV
« on: 29 December 2009, 19:31:08 »
How long to swap HBV on V6 ?  Is there a howto?
  • Online Online
Re: HBV
« Reply #1 on: 29 December 2009, 19:43:09 »
« Last Edit: 29 December 2009, 19:43:20 by tunnie »
Re: HBV
« Reply #2 on: 29 December 2009, 19:48:09 »
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
Easy to find in the maint index  ;)
Thanx Tunnie - lazyness rules ok  ;)
Know how to get it out - just wanted confirmation that plenum could stay on - more interested in a time from one who has done this - particularly in this cold snap !!!
  • Online Online
Re: HBV
« Reply #3 on: 29 December 2009, 19:54:19 »
Times will vary, what DTM does in minutes, takes the rest of us hours  ;D ;D
Re: HBV
« Reply #4 on: 29 December 2009, 20:27:45 »
Would have thought an hour and half should see this through?
Re: HBV
« Reply #5 on: 29 December 2009, 21:04:38 »
Ive done it without removing scuttle or plenum
fiddley, but doable in 15 minutes  :y
GPar
  • Chatham, Kent
Re: HBV
« Reply #6 on: 29 December 2009, 23:21:02 »
Remove scuttle but not plenum and get a pair of those special pliars to remove the hose clips. About an hour with a lot of stretching!
Geoff
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: HBV
« Reply #7 on: 29 December 2009, 23:26:15 »
with ten coffee breaks maybe.
scuttle off & about 15 mins to half hour i would say. ;D
Re: HBV
« Reply #8 on: 30 December 2009, 02:08:22 »
Want to do mine Jim?
« Last Edit: 30 December 2009, 02:08:36 by dbug »
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: HBV
« Reply #9 on: 30 December 2009, 08:01:03 »
Took me 20 minutes in all. Dead easy and no skin loss for once. Hardest part was getting the top lip of the scuttle back under the windscreen seal.
Give it a good run and bleed off afterwards with the Vac pipe off the HBV to make it stay wide open. Cabin temp set to maximum. Replace when it has been fully air bled and topped up to its correct level with coolant.
GudLuk
Omegadoha, Desert Member
  • Doha, Qatar
Re: HBV
« Reply #10 on: 30 December 2009, 08:10:44 »
Does it knacker your back? all that bending over.
Re: HBV
« Reply #11 on: 30 December 2009, 09:05:57 »
If your passing this way  :y
3 hours drive each way not very appealing  ;D ;D ;D
I_want_an_Omega
Re: HBV
« Reply #12 on: 30 December 2009, 10:37:55 »
Bit of a stupid question - but do you have to drain the cooling system totally or just top up what was lost?
Re: HBV
« Reply #13 on: 30 December 2009, 11:57:14 »
Hoping you might be down my way  ;)
Guess not and I'll have to do it myself  :( (when it stops raining!!)
Re: HBV
« Reply #14 on: 31 December 2009, 18:59:28 »
Well changed the HBV on the Estate today and I've got the scars to prove it - just over the hour (I take my hat off to Jimbob with his 15 minutes!!).  Bl**dy awkward thing to get at even with skuttle off - b*gger to get the hose clips moved back and also a b*gger to get the pipes off the old one (welded on?)
Fitting new one much quicker, top up water, allow to bleed and test run - all ok so far!!
